Old 04-01-12, 07:50 PM   #1
SV Mad
Default Air box mod for free.
Read in this months Fast Bikes that you can remove the top of the air box under the fuel tank and just have the air filter with the tank acting as the top cover.
It apparently improves the airflow and gives a couple of extra Nm of torque.
Anyone done this, and is it as simple as it sounds?
Cris.
Old 04-01-12, 08:33 PM   #2
tom-k6
Default Re: Air box mod for free....
im sure you can, but the filter would be loose, collect extra amounts of dirt such as small rodents and pigeons :P but the fueling would need to be altered to suit the larger "air box"
not going to try this one myself mind.
Old 04-01-12, 08:54 PM   #3
http://forums.sv650.org/showthread.php?t=173588
Old 05-01-12, 10:22 AM   #4
johnnyrod
johnnyrod's Avatar
Something for nothing? Whaddyer reckon?
Old 05-01-12, 10:24 AM   #5
SV650Racer
Not the most effective way of modding your airbox to work better, in fact you may just find you get more noise and thats it!
Old 07-01-12, 03:27 AM   #6
Destruktor77
My brother did this to his 2003 after reading Fast Bikes. He screwed the filter down with some mesh type stuff, he says the sound is awesome and the front comes up a bit more than it used to so I'd guess it's worth a try.
Old 07-01-12, 09:58 PM   #7
Fallout
Fallout's Avatar
I remember when I got my bike (private), I dropped it off at a garage for a once over and a service. They said the air filter wasn't even attached. It was probably this mod then. I've since changed my air filter myself, and I'm pretty sure the lid holds the filter in place, so as has been said above, you'd need to hold it in place somewhere. I might give it a bash myself and see what happens. Will report back if I do.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 08-01-12, 10:19 PM   #8
Mark_h
Mark_h's Avatar
My SV1000 has a BMC filter and no top on the airbox. It has a custom fit aluminium plate that fits the edge of the filter and screws into the original screw holes. Was supplied by BMC racing before I got the bike and I've had no problems at all. Is pretty loud though. If you do it make sure you take any flappy foam of the bottom of the tank.
Filter + m4 2:1 system added about 15 bhp if I remember according to the dyno print outs that were in with the paperwork
Minister for Sustainability
Old 09-01-12, 12:40 PM   #9
johnnyrod
johnnyrod's Avatar
Originally Posted by Mark_h View Post
... dyno ...
Therein lies the key. More air needs setting up accordingly.
Old 09-01-12, 05:35 PM   #10
SV Mad
Think I'll just leave this mod to the racers and not bother. Although at the next service I might take the top off and start her up to listen to the difference.
my free front paddock stand - well almost free ! mike_avfc Bikes - Talk & Issues 34 29-07-09 06:27 PM
hel braided lines for k5 pointy, k5 shock absorber (free) and 2 x snow plows (free) Paul the 6th For Sale - SV's and SV related items 9 30-06-09 02:47 PM
indicators free yes free hall13uk Soho Massive 6 11-03-05 02:52 PM
