Old 06-01-12, 08:48 PM   #1
Default Fitting (Shoehorning) a Stebel Nautalus onto a Curvy
As the title says really
I'm needing a couple of pics to see how everyone else has done it.
Also I'm need to know how to wire it in.
Thanks in advance
Old 06-01-12, 08:56 PM   #2
Default Re: Fitting (Shoehorning) a Stebel Nautalus onto a Curvy
Split the horn from the compressor makes shoehorning it in much easier. I followed the instructions here
http://www.motorcycleinfo.co.uk/inde...pageId=2173985
Compressor goes under the seat, and the horn well put it where it fits, but preferably with the trumpet pointing downwards.
My horn part is in the left fairing upper.
Use the wiring from the OEM horn to power the relay.
http://forums.sv650.org/showthread.php?t=162784
The compact nautilus horn is half the size of the standard
Old 06-01-12, 09:10 PM   #3
Excellent Mavi
The ebay listing I won it claimed it was squeezed onto a GSXR750 K8 (and its the compact)
You wouldn't know off hand what the I/D of the curvy fuel lines are
Old 06-01-12, 09:25 PM   #4
6mm I think.
Is that for connecting to the compressor?
You can use something like windscreen washer tubing.
Old 06-01-12, 09:27 PM   #5
Yeah as need to replace the lines from the tank and I'll get some more when a order it
Old 06-01-12, 09:30 PM   #6
Oh, don't use the windscreen washer tubing for the fuel lines, its not petrol proof
Old 06-01-12, 09:41 PM   #7
haha
Just been looking at the Pirtek catalouge for half decent hose
Old 06-01-12, 09:41 PM   #8
punyXpress
punyXpress's Avatar
No amount of ' audible warning of approach ' will keep you out of her Majesty's hedgerows!
Now: Street Triple R
Old 06-01-12, 09:52 PM   #9
Wets should cure that
Old 06-01-12, 10:57 PM   #10
SoulKiss
SoulKiss's Avatar
Well I managed to fit a Magnum AND a Nautilus on my Z750 - as well as retaining the stock horn
Stebel Magnum fitting questions. daveyrach SV Talk, Tuning & Tweaking 14 17-05-11 09:02 AM
Hiding a Stebel Nautilus on a Curvy maviczap SV Talk, Tuning & Tweaking 0 21-02-09 11:35 AM
Stebel Nautilus on naked...fitting help 600+ SV Talk, Tuning & Tweaking 15 15-05-07 09:47 AM
Stebel Magum Fitting on a Pointy. danf1234 SV Talk, Tuning & Tweaking 26 04-05-07 04:44 PM
Stebel Magnum horn - fitting Tigerrrr....... SV Talk, Tuning & Tweaking 3 23-09-06 09:45 PM
