Old 22-01-12, 06:20 PM   #1
neil.t.franklin
Default 1999 Neutral switch part number?
Hi, I have googled this but I can not find the part number for a replacement Neutral Switch. Does any one knows of this part no. ?
Thanks for any help.
Old 22-01-12, 06:39 PM   #2
rictus01
rictus01's Avatar
Default Re: 1999 Neutral switch
you'll find the parts fiche here, you'll have to trawl through and find the part number yourself though, they are below each diagram.
Cheers Mark.
Old 22-01-12, 06:43 PM   #3
neil.t.franklin
Thanks Mark!
Old 22-01-12, 06:56 PM   #4
neil.t.franklin
I see why I had trouble finding it. It comes under:
37720-20F00 GEAR SHIFT TERMINAL BASE ASSY
Regards
Old 22-01-12, 07:00 PM   #5
rictus01
rictus01's Avatar
you have discounted a wiring fault first though right ?
Old 22-01-12, 07:06 PM   #6
neil.t.franklin
It was my mistake, I was heating up the front sprocket nut for removal and the wiring to the switch caught fire.
It looks un-salvageable.
I'm doing a complete rebuild so not to much of a problem.
Thanks again.
Old 22-01-12, 07:09 PM   #7
rictus01
rictus01's Avatar
no worries.
Ignition switch - Are the 1999 N and S the same? cammy SV Talk, Tuning & Tweaking 3 02-05-09 09:07 PM
Part number? BILLY SV Talk, Tuning & Tweaking 3 30-11-06 12:03 AM
Neutral indicator light switch / ignitior retarder??? pipster SV Talk, Tuning & Tweaking 8 06-11-06 03:52 PM
Anyone Know: Part number for a bolt? Kinvig SV Talk, Tuning & Tweaking 13 12-10-06 03:16 PM
Part Number for K&N The Mass SV Talk, Tuning & Tweaking 10 24-03-05 05:14 PM
