Old 07-02-12, 08:46 PM   #1
ghigo
Default hayabusa rear shock oil?
which oil do i need for a mk1 busa rear shock and where to buy from?
Old 08-02-12, 10:32 AM   #2
ghigo
Default Re: hayabusa rear shock oil?
anyone ???
Old 08-02-12, 07:53 PM   #3
MattCollins
Look it up in the workshop manual... it should be in there.
Fair bet it is a 5W (16-18cSt) synthetic. I'd suggest Redline.
Old 08-02-12, 10:29 PM   #4
i may be wrong but i don't think you can diy service a busa rear shock.
better getting someone to do it for you unless you have access to a nitrogen/needle and all the tools to take it apart. think its only about £100 to have one serviced. you could ask Y_C as i think he does them.
Old 09-02-12, 06:57 AM   #5
m`baubz
you hardly need any special tools to take the shock apart. spring compressors maybe, but
you can do away with ratchet straps. and I think the busa shock has a schrader valve under
the shiny cap, so releasing the nitrogen isn't a problem. after you're done with the rebuild,
take it to a shop to have it filled.
as for shock fluid, i've no idea what you have available locally, but you should look for the
highest viscosity index (VI). Redline, slikolene pro rsf 2.5 or motul should be fine.
Old 09-02-12, 10:27 PM   #6
ghigo
cheers guys
It's a Hayabusa or is it? TheRamJam Bikes - Talk & Issues 20 25-04-10 08:30 PM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
FOR SALE: 05 Hayabusa rear wheel yorkie_chris Idle Banter 0 02-04-08 07:49 PM
Rear shock sprocket SV Talk, Tuning & Tweaking 3 17-05-05 10:50 PM
rear shock matsv650s SV Talk, Tuning & Tweaking 7 02-02-05 07:01 PM
