Mini-Twins Goto Minitwins Official Site
Old 08-02-12, 10:11 PM   #1
Bucks108
Default Best Throttle Tube?
Hi All,
I've heard that putting an R6 throttle tube gives quicker throttle response as the travel isn't as far as the standard SV throttle tube. Has anyone got any experience of this?
Cheers,
Martin
Old 09-02-12, 08:10 PM   #2
Winder
Winder's Avatar
Default Re: Best Throttle Tube?
Done it on my road bike and didn't really notice the difference. Venhill QA is quite cheap and works perfect
Old 09-02-12, 08:17 PM   #3
Strange, as I thought the R6 mod I did to mine was one of the best and cheapest mods I've done.
Changes the action noticeably and can be done in about 10mins
Old 09-02-12, 08:23 PM   #4
Winder
Winder's Avatar
Well I thought it was gash, maybe because I had been riding a old hornet with a very short turn throttle for a long time before the SV?
Anyway, make your own mind up, if you search the forum you can find the part number.
5 minute job on a curvy, requires slight modification for a pointy ( or so I'm told )
Old 10-02-12, 10:02 PM   #5
Bucks108
Thanks for the replies guys. If its only a quick job i'll give it a go and see how it feels.
Cheers,
Martin
Old 21-04-12, 06:22 PM   #6
sicknote
bumping an old thread here, I just attempted to fit an R6 5EB throttle tube to my gen-1 sv.
With the r6 tube in there, i had to pull a load of slack cable with the adjusters below the throttle,
not enough adjustment really available so it will mean messing with the adjusters hiding under the airbox
in order to get the throttle freeplay set. not a 5 minute job.
To make matters worse i can detect little difference in the reach of the throttle from the SV item.
seems to be something of a bogus upgrade !
Old 22-04-12, 12:24 AM   #7
Winder
Winder's Avatar
Is your bike naked?
Old 22-04-12, 06:42 AM   #8
sicknote
@winder no, faired,sv650s
on the left in the pic is the tube i was sold as r6 throttle tube ,
on the right OE sv650s item
i can see now why i had to wind the adjusters out, there is a big bit of plastic flesh missing. it is otherwise quite similar.
does this look right ?
Old 22-04-12, 07:04 AM   #9
NTECUK
NTECUK's Avatar
For a gen 1 faired it works fine
Old 28-06-12, 07:02 PM   #10
konceppt
5 minute job? nope.I cant even undo the screw holding the bar end on lol
Now its rounded off and will need drilling out.Cant be arsed doing it tonight so maybe at the weekend.
P.s) I was under the impression it was a 5sl throttle tube needed not a 5eb.I have a 5sl tube anyway
R6 Throttle tube mod done Lozzo SV Talk, Tuning & Tweaking 7 06-02-13 03:28 PM
Throttle Tube for a K3 S - will an 'N' fit? Hoody90 SV Talk, Tuning & Tweaking 1 16-03-11 08:20 PM
Throttle Tube PuggledPrune Stuff Wanted 0 10-03-11 01:08 PM
R6 throttle tube - no cut or cut ? barwel1992 SV Talk, Tuning & Tweaking 7 09-08-10 10:56 PM
R6 throttle tube Quiff Wichard SV Talk, Tuning & Tweaking 34 04-06-06 08:42 AM
