Old 18-02-12, 08:29 PM   #1
Dave20046
Dave20046's Avatar
Default Rear shocker similar to k1 gsxr 1000?
I know there's loads on this, but been searching, and searching via google - and still not found what I need so wondering if anyone knew the answer.
I've currently a k1(I think) gsxr 1000 shock in my sv650s, I want to swap it for something suited to a 12 stone rider*... is there a straight swap I can do?
* I'm assuming it's not suited to a 12 stone rider as it was harsh, now i've lost a bit of weight it's harsh as ****
Old 18-02-12, 08:46 PM   #2
davepreston
Default Re: Rear shocker similar to k1 gsxr 1000?
eat more pies
Old 18-02-12, 08:48 PM   #3
Eat a lot more pies
Old 18-02-12, 09:30 PM   #4
Dave20046
Dave20046's Avatar
All my pies have been donated to the needy
Old 18-02-12, 10:07 PM   #5
joshwalker094
joshwalker094's Avatar
hmm dave, would your shock be suited for about 16 stone rider on a pointy and fine with pillion up to 18stone and luggage?
Old 18-02-12, 11:05 PM   #6
according to the racetech calculator (take with a pinch of salt) the standard spring is ideal for your weight in fact they say its a bit soft.
what the problem might be is that the oil is getting a bit old and the valving is grotted up.
you may also have the spring wound up to much or not enough so the damper is not sitting at the correct part of the stroke. also having lost weight you will need to adjust the valving again.
when was the last time you checked the 'ride hight'?
as a rule i always err on the softer side for on the road. i have also found on my bike if the rear susspension is too soft the bike will 'weave and wallow' in straight lines, too hard and it skips and jumps about with a 'loose vague' feeling to the rear. get it in the ball park and it instantly feels planted then it's just a case of fine tweaking.
Old 19-02-12, 02:48 AM   #7
Dave20046
Dave20046's Avatar
tbh bibs I've not reset the suspension for along time, when I first got the bike it was a tad harsh (needing a wee every 30 miles) and the old owner (massive member of the site ) said it was the right shock for his weight which was slightly heavier than I was, it's now well ready for a service so my thinking was, rather than servicing the shock getting something pre-serviced that's the right weight for me...but if the shock just needs a service that's a bonus
Just don't want to be wasting my pennies
Old 19-02-12, 02:50 AM   #8
Dave20046
Dave20046's Avatar
For the sake of a sale , yes
to be honest though it probably would be, needs a service though.
Old 19-02-12, 03:38 AM   #9
only way your going to now if the spring is the right weight is to set the sag. cant remember off hand what the sizes are but 10mm bike and 25mm rider springs to mind. if the bike falls within the sizes then the spring is right. if you fall short of the rider sag when you have got the bike sag then the spring is to heavy.
TBH though its more likely to be your comp and rebound settings. if you have wound them up to much then the shock will not move giving a harsh ride.
it's about £70-100 to get a shock serviced and in my opinion would be worth it as you then have a nice fresh shock instead of getting another one that you don't know the history of. if you need a different spring they would probably do one for around another £20-30 while they are at it. might also be worth asking about replacing the shim stack for something a bit more compliant.
Old 19-02-12, 12:10 PM   #10
Dave20046
Dave20046's Avatar
Cheers bibio, I'll check the sag and see where we are.
gsxr 1000 k8 rear wheel AirArmed For Sale - Other Bikes and General biking items 3 11-04-11 08:50 PM
Hagon/Nitron/gsxr rear shocker opinions - Gladius. chilli SV Talk, Tuning & Tweaking 24 28-03-11 03:24 PM
new gsxr shocker fitted. tommy-d SV Talk, Tuning & Tweaking 4 18-02-10 09:10 AM
GSXR 1000 rear shock. Bill.Cross SV Talk, Tuning & Tweaking 5 01-12-08 08:42 PM
GSXR 1000 K5-6 rear shock with link DanF For Sale - SV's and SV related items 0 15-03-08 11:15 AM
