Old 19-02-12, 10:10 PM   #1
muzikill
muzikill's Avatar
Default Sv new oem bolts?
Can anyone tell me how long its been since suzuki replaced the oem bolts with shiny chrome/steel ones? I went to see the new gixxer and noticed the sv has had a makeover boltwise.
Old 19-02-12, 10:11 PM   #2
Default Re: Sv new oem bolts?
They used some stainless on even curvy... Which bolts exactly.
Old 19-02-12, 10:13 PM   #3
m1tch_1987
Ive not tried this company, but they do full bolt kits for all bikes:
http://www.pro-bolt.com/index.php/mo...le/suzuki.html
Old 19-02-12, 10:30 PM   #4
muzikill
muzikill's Avatar
Ive got the chewy kit, I noticed that on the new sv theres shiny bolts for the brake calipers and the brake hose banjos are all oem shiny now.
Various bolts mackrilld SV Talk, Tuning & Tweaking 2 08-05-09 11:36 AM
Bolts Duck-man SV Talk, Tuning & Tweaking 7 19-03-07 01:09 PM
i need some bolts dirtydog Bikes - Talk & Issues 12 07-05-06 01:43 PM
Long bolts? Short bolts? andyaikido SV Talk, Tuning & Tweaking 6 25-01-06 04:53 PM
LED Bolts BoltonSte SV Talk, Tuning & Tweaking 9 29-11-05 08:13 PM
