Old 22-02-12, 05:19 PM   #1
hongman
Default Recommendations; supension, tyres, chain etc.
So I am finally in a position to be able to get the bits I need to get my beloved back on the road.
She's been under a cover since AR11 so I'm anticipating the battery will need a charge at the very least.
Before I go and spend on the first thing that takes my fancy, thought I'd see if people know of any decent deals and/or anything else to take into consideration.
I'm planning on doing a fair amount of miles this year
- Battery Charger. I dont need one of these "battery-on-charge-for-months" optimisers, just something to charge a dead battery up.
- Rear Tyre. As I have Avon Storm 2's on the front with a bit left I might as well get another for the rear. Was just going to ebay/google, unless anyone else had any ideas.
- C&S set. Got a link for an Ebay set at home, dont think there is anything special I need to consider. Keeping my -1T front on as that is only had couple months use.
- Springs. After much deliberation, I'm going to just go for springs first. K-tech linear 0.85's if I remember rightly.
It had an oil change after the AR and not rode since, so that'll be fine.
I'll check the brakes also as they have been standing for a bit but should be ok.
Thanks!
H
Old 22-02-12, 09:04 PM   #2
Nobbylad
Nobbylad's Avatar
Default Re: Recommendations please!
I reckon you could chop it in for a half decent pointy, job jobbed.
HTH
Old 22-02-12, 09:06 PM   #3
They don't exist
Old 22-02-12, 09:08 PM   #4
-Ralph-
Want the charger to be cheap then? http://www.ebay.co.uk/itm/12V-BATTER...-/230628397848
Make sure you buy a fork oil with a cst@40 value of 33-40, whether it's 5wt or 15wt doesn't matter a toss, it's the kinetic viscosity that matters. The viscosity of the Suzuki G10 fork oil is 33.
Old 22-02-12, 09:14 PM   #5
Want the charger to be cheap then? http://www.ebay.co.uk/itm/12V-BATTER...-/230628397848.
Hong, I've got one like that kicking around, you can have it for the postage
Old 22-02-12, 09:26 PM   #6
hongman
lolpointy
Will that type of charger work for charging up flat batteries - I only ask as it is described as a trickle charger? How would I know how long to leave it plugged in for?
and thanks Ralph for the cst thing, saved me looking it up
Old 22-02-12, 09:36 PM   #7
hongman
http://www.mandp.co.uk/productinfo.a...d-Sprocket-Kit
Good?
Old 22-02-12, 09:41 PM   #8
Well its not one of them fancy chargers like my Optimate which can revive dead batteries.
But being a trickle charger means you can leave it on without it overcharging
Old 22-02-12, 09:43 PM   #9
hongman
I think I might well need a fancier one. Going to check out Optimate. Was it Oxford that did one was well.
Old 22-02-12, 09:45 PM   #10
SIII
SIII's Avatar
Cheapest price I found for Storm II's waswww.OPONEO.co.uk. Cost £106 delivered for a rear. Delivery does take a week tho', comes all the way from Poland! They were recommende to me by someone on here.
http://www.oponeo.co.uk/tyre-details...7-69-w-rear-tl
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground"
The Stoppy King
SIII is offline   Reply With Quote
Bike Tyres Leeds - free fitting on Michelin Tyres through Feb & March Paul the 6th Pennine Massive 14 03-03-12 04:59 PM
Commuting Tyres? Recommendations? BigG SV Ecosse 7 17-05-10 07:58 PM
Recommendations for tyres near Sidcup area muffles Bikes - Talk & Issues 8 11-05-10 06:08 PM
Tyres again! New tyres to replace stock ones metalmonkey SV Talk, Tuning & Tweaking 12 01-07-08 05:48 AM
Weird Supension problem AlfBoy SV Talk, Tuning & Tweaking 11 23-12-05 03:55 AM
