Yet again i need the orgs help please. I was at the Ponderosa today, as I went to leave and turned the key in ignition absolutley nothing happened.
Tried jump leads, checked fuses, wiggled wires, some people who seemed to know what they were doing helped but had to call breakdown service in the end. From what i've read I think it's the reg/rec as it seems quite a common issue so if you agree I'll search for info on here with regards to replacing it. |
I suspect:- Green 'ignition barrel to loom' connector.
http://forums.sv650.org/attachment.p...8&d=1309299692 Lift the tank, take off top of airbox and then disconect bottom of airbox from throttle bodies and push it backwards to get access to the connector which is at the back of the headstock. Open it up and take a look.
SK9 Sport Black Delkevic can. Non arbores caesa suum mittere nuntius, sed magnum numerum electrons uehementissime incommo. Last edited by Shawthing; 03-03-12 at 10:52 PM. |
Had a similar issue on a scooter (don't laugh) i once owned, it turned out to be a hairline crack in the protective outer of one of the cables in the wiring loom where it went round the frame and had rubbed causing it to short out on the frame when trying to start. I don't know where the loom runs on the sv but if it runs near the frame it is worth checking. I fixed it with lots of electricians tape.
#4 | |
Just thought about this and i think it also blew a fuse as well, and you say your fuses are ok, so it probably is not this but still may be worth checking. |
#5 | |
When you say nothing happened did you get any instrument lights or clicking or is it totally dead? Battery got any charge?
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
![]() ![]() photo by Speedyctr, on Flickr Thanks for pointing me in the right direction. I took top off the airbox and just checked the connections I could get to. I just poked around in there and it came on! I think the one to the top of the picture (which is on the right side of bike) was the culprit bit that goes to speed sensor which I did replace recently so I could have pulled it then. It that wouldn't stop everything from working would it? I need to discover which one came loose so it doesn't happen again. Might take lower part of airbox off now to get a better look. Just to clarify there was absolutely nothing working before as if there was no battery. Last edited by speedyctr; 04-03-12 at 11:35 AM. |
Virtually All bike's power goes through the GREEN connector.
This is the one you need to take apart. Loosen the two screws that clamp the bottom of the airbox to the two throttle bodies. Lift the airbox and push it backwards. The green connector shoud be able to be slid upwards towards you then. Worth checking internals of all the connectors though. Depending on what you find, and what if any ancillary power hungry additions you have on the bike ( heated grips etc) ,though you will need to make a decision on the type of repair to stop this occuring to you again. ( cleaning and refititng contacts, fitting bypass parallel wiring, additional relays and power wiring, fitting replacement sealed connector, hard wiring ignition barrel to the loom )
SK9 Sport Black Delkevic can. Non arbores caesa suum mittere nuntius, sed magnum numerum electrons uehementissime incommo. Last edited by Shawthing; 04-03-12 at 03:23 PM. |
#9 |
Manage to get to green connector last weekend and it was the textbook fried connector!
Couple of snips and bit of soldering and it is sweet again ![]() |
2008 sv650 clutch issue & abs issue | my_galaxy | Bikes - Talk & Issues | 4 | 29-06-11 12:03 PM |
Electrical Issue? | evo-orange | Bikes - Talk & Issues | 7 | 17-03-11 09:08 PM |
Strange electrical and mechanical cutting out issue | Son of a beesting | SV Talk, Tuning & Tweaking | 13 | 07-08-09 08:38 AM |
Dropped, won't start: clutch or electrical | nicholasv | SV Talk, Tuning & Tweaking | 8 | 28-10-08 06:23 PM |
Electrical problem: My bike won't start. | Tim in Belgium | SV Talk, Tuning & Tweaking | 9 | 13-04-08 07:19 PM |
