Old 16-03-12, 05:03 PM   #1
ruddlad
Default Dropped seat bolt.
I got a bolt to fit the seat then dropped the little b*gger, I cannot find it anywhere, where's the most likely point it will go to? I heard a clank so it hit metal, I have checked chain and wheeled bike around but cannot find it anywhere!! Concerned it may cause a problem when starting up.
ruddlad is offline   Reply With Quote
Old 16-03-12, 05:11 PM   #2
TamSV
TamSV's Avatar
Default Re: dropped seat bolt
Assuming you were in the general area of the seat, check all round the front end of the swingarm. Lots of nooks and crannies around there to catch a bolt.
Old 16-03-12, 05:21 PM   #3
Huwbee
Wedged in by rear shock absorber /spring or on top of the exhaust headers/pipe
Old 16-03-12, 05:21 PM   #4
hardhat_harry
magnet on a stick??
Old 16-03-12, 05:38 PM   #5
jambo
jambo's Avatar
Go for a ride over some pot holes.
Buy a new bolt.
Old 16-03-12, 05:39 PM   #6
You'll never find it, same happened to me.
Buy a new one
Old 16-03-12, 05:52 PM   #7
ruddlad
Was just concerned it may cause damage, have bounced, rocked, tilted the bike and nothing moved, or sounded like it was catching.
Old 16-03-12, 06:02 PM   #8
Under the lawn mower
Old 17-03-12, 12:57 PM   #9
benji106
I did the same thing, couldn't find the bugger anywhere, assumed the garage had swallowed it, and next time I rode it found out on the M4, it had got caught in the rear brake linkage, and jammed my rear brake on slightly, cue smoke, boiling brake fluid spraying everywhere etc.
Suggest you check there!
Old 17-03-12, 02:55 PM   #10
ruddlad
Been out on it twice and nothing untoward. I have searched high and low for it. It was the left side as you sit on the bike, so immediate concern was chain.sprockets etc. I have a new shed for it so hadn't fell onto floor or I'd have noticed.
Seat Bolt size? ruddlad SV Talk, Tuning & Tweaking 4 16-03-12 02:53 PM
Seat panel bolt - Pointy DarrenSV650S SV Talk, Tuning & Tweaking 12 09-06-11 11:19 PM
Seat Bolt and bar end bolt Colby Stuff Wanted 3 04-04-07 04:56 PM
Seat bolt wanted Chig Stuff Wanted 7 17-02-06 03:17 PM
Rad mount bolt missing/dropped out? Reckless Rat SV Talk, Tuning & Tweaking 2 11-07-05 01:30 PM
