Old 17-03-12, 10:21 PM   #1
joshwalker094
joshwalker094's Avatar
Default Which relay for LED indicators?
hey guys, just fitted bike it led indies all round,
so need a realy for them now, so where do i get one for them. or how do i get around it all since they are flashing really fast
Thanks
Josh
RIP Reeder
JOSH WALKERRRRRRRRRRRR
Old 17-03-12, 10:24 PM   #2
MisterTommyH
MisterTommyH's Avatar
Default Re: Led indicators relay
http://www.ebay.co.uk/itm/Indicator-...ht_1743wt_1037
MisterTommyH is offline   Reply With Quote
Old 17-03-12, 10:25 PM   #3
Epic Monkey
This is the one I bought.
http://item.mobileweb.ebay.co.uk/vie...d=190623520610
I did buy a cheaper one off eBay but it was rubbish.
Old 17-03-12, 10:29 PM   #4
joshwalker094
cheers guys, ive been told you need a specail one cause the relay has the side stand switch and something else in it, told they were £80 from suzuki.
RIP Reeder
Old 17-03-12, 10:35 PM   #5
MisterTommyH
I've got the same bike as you, and I got a cheap e-bay one a year ago. Never had a problem with it.
Old 17-03-12, 10:36 PM   #6
joshwalker094
just got the haynes out and it says ' the sidestand switch relay and diode and the neutral/gear position switch diode are intergrated into one component with the turn signal relay' so are those relays fine for this job
RIP Reeder
Old 17-03-12, 10:49 PM   #7
Robw#70
just get a two wire one and pull the two connectors out of the back of the relay
Old 17-03-12, 11:43 PM   #8
joshwalker094
Don't get you rob, I have no idea when it comes to electrics and mechanics really.
RIP Reeder
Old 18-03-12, 12:23 AM   #9
Epic Monkey
Those 7 pin Suzuki relays we linked to will be fine. I have that specific one I linked to and have no issues with neural lights etc. I did however need to retain 1 pair of inline resistors to maintain proper flash rate. The cheaper eBay one incl the replacement the guy sent out never flashed properly at all.
Old 18-03-12, 06:36 AM   #10
dkid
Covered many times on here, see links in this thread.
http://forums.sv650.org/showthread.php?t=174160
Aftermarket Indicators flashing too quick - which relay? bikeramy SV Talk, Tuning & Tweaking 7 10-05-13 07:01 PM
LED indicators - different relay needed? forky SV Talk, Tuning & Tweaking 3 01-11-11 08:56 PM
Starter Relay, Starter Relay connector, Rear cush drive rubbers. yorkie_chris Stuff Wanted 4 08-07-11 09:32 PM
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
