I have a Tutoro Manual Oiler fitted and have noticed that I am getting little streaks of oil on the tyres sidewall and on the edge of the tread. I have the drip rate set just right, any lower and no oil comes out, which is about 1 drip per 1 - 1.30 minutes. The oil streaks are only on the edge of the tread where I havent ridden on. Will get pictures tomorrow. How can I prevent this?
It sounds like you are over oiling, Do bare in mind that a tube should oil for about a hundred miles. Are you using a twin or single feed tube on your sprocket?
If in doubt, have a look here for set up advice. |
Thats the thing. It lasts roughly 100 miles as it is. The other day I opened it an 1/8 of turn less and after 50 miles I checked the tube and nothing had come out. I currently only turn the valve 1 and 1/4 turns out. 1 and 1/8 and no oil comes out. I really like the Tutoro, its cheap, simple, really easy to fit and does the job, just need to try and stop oil flinging. (I have the twin nozzle)
You will never stop all fling as the used oil has to go somewhere after the chain, same with aerosols.
So if you get some light streaks then thats pretty normal, if the tyre gets wet with oil then it's too much. Same happens with Scot oilers and all others as it's the way they work and I've used scot oilers since the '80s. Just got the new Automatic Tutoro oiler and very pleased with it. But, like the scot oilers I only ever use a single sided nozzle, you really don't need both sides, so it may help if you just use one nozzle on the outside of the sprocket.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers |
Light fling is unavoidable with any chain oiler, that's how they work. The dirty oil flings off the outside of the chain and gets replaced with clean oil on the inside (from the sprocket).
My SV had a Tutoro with the twin feed nozzle and I tuned that down to about 1. 1/4 turns, the oil lasted over 200 miles and the chain always looked wet and clean. Yours might have a bit of gunge or other crap on the thread stopping you from getting such fine adjustment so it is worth having the adjuster out completely and giving it a clean out. I'm a convert to chain oiler's, mine was fitted with a new chain and sprocket set and after 8K miles the chain was still well within adjustment with no tight spots, it was never adjusted after fitting and the only reason I don't have one on the Triumph is that the chain is on the way out, and it would be a bugger to fit one neatly, it would have to go to the front sprocket. |
I have both the Auto and the manual and use a single feed on the auto and twin on the manual. For me, the twin feed delivers too much oil and you get more fling, usually all over my wheel, which being silver really shows. However, given that I have barely adjusted my chain and it runs so smooth, I would rather have a little fling than a dry chain.
This is a very good point. |
Tutoro Chain Oiler | RavenWire | Hardware | 25 | 11-05-12 09:52 PM |
tutoro chain oiler? | aaron020873 | Bikes - Talk & Issues | 21 | 16-11-11 08:32 PM |
SV chain oiler | embee | Photos | 21 | 30-03-11 07:29 PM |
Chain oiler; do you use one? | bengrrr | Bikes - Talk & Issues | 13 | 13-07-10 04:25 PM |
Tutoro Chain Oiler | Gabriel2k | Ancillaries | 19 | 09-06-10 05:05 PM |
