Ok.
VFR as you know. my right mirror is fine.. will push in and pull out and stay in position tightly left one. once pushed in.. when pulled out is all floppy and lose and requires the use of the allen key to nip it up.. is there a washer missing or a corrugated washer or what?? |
Had similar on my curvy... The bolt is slightly seized onto the arm. I fixed it by disassembly, clean up, copper slip on touching surfaces and a bit of threadlock on the bolt.
Over use from doing your makeup...?
thank you for a serious response Michael
Speed- your sd card will be winging its way returning to you very soon |
No hurry for it
![]() Post it when you can. |
How to tighten rear suspension on 01 sv650? | RGSPro | SV Talk, Tuning & Tweaking | 22 | 13-09-12 06:21 PM |
How do i tighten my suspension? | nerd | Bikes - Talk & Issues | 9 | 20-08-09 12:45 PM |
Pointy mirror pivot won't tighten | thor | SV Talk, Tuning & Tweaking | 4 | 01-10-08 11:56 AM |
How often should I tighten the chain? | Ed | Bikes - Talk & Issues | 2 | 08-10-06 09:24 PM |
How to tighten / loosen round nuts on steering stem?? | Khewett | SV Talk, Tuning & Tweaking | 4 | 14-05-06 09:33 AM |
