Old 20-04-12, 01:10 PM   #1
Mr Fast
Default Intake leak?
hey guys im new here. had my sv for 8 months now and has slowly become my baby lol had the TLR before and quickly found out the sv's so much more fun.
anyway i got home last night and everything was fine, just gone to the garage to fire her up and lots! of popping and banging. pluged in my carb tune and couldnt beleive how far out they are. about 8 bars ! ive checked the air lines ive check the boots ive checked the spark. there is a sucking noise coming from the front carb but cant see any leaks at all. ive had the carbs of and everything looks fine. have i missed something small or am i looking at a big problem. ive had bad carb issues before but nothing this bad
any advice would be greatly welcome
thanks guys
Old 20-04-12, 01:12 PM   #2
Default Re: Somethings gone wrong !
Is the air box sealed on the carb rubber properly
Split somewhere where you can't see
Old 20-04-12, 01:16 PM   #3
Mr Fast
runs the same with the box on or off. when i tried to sync the carbs i had to turn the screw so far out it nearly fell out and still nowhere near ?? im stumped !
Old 20-04-12, 01:20 PM   #4
would help if we knew what version you have MK1 (carbed) or MK2 (injection)
inlet rubber, or loose spark plug.
don't know if a dropped jet would affect vacuum (carbed)?
Old 20-04-12, 01:24 PM   #5
Mr Fast
curvy 2000 plate. ive checked the spark plug and checked the inlet rubbers. ive had the carbs off and everything looks fine. obviously its got no ram air system to complicate things so its fairly easy to check for leaks. im gonna go and have another pok around but im 95% sure theres no leaks
Old 20-04-12, 01:29 PM   #6
twowheels
the rubbers that cover the inlet stubs on the carbs - are they in tact and both on??
Old 20-04-12, 01:29 PM   #7
is it the front carb that's reading high?
Old 20-04-12, 03:34 PM   #8
Mr Fast
Default Re: Intake leak?
no its the rear. the bar on the carb tune is at its highest point and the front is about 2 bars from bottom. the choke seems to be playing up. when i put the choke on instead of reving faster the bike stalls. when i put the choke on a little the carb tune bar for the rear cyclinder drops a little.
ive disconected the choke from the carb, cleaned and reconnected and still not working.
just to recap ive checked the vacuum lines, rubber inlets, choke and every other pipe and wire connected to the carbs.
could the problem be inside the carbs and if so what might that be.
ive got to travel 110 miles to see the old girl tomorrow and really need to get this going.
cheers guys
Old 20-04-12, 03:35 PM   #9
Mr Fast
also could it be fuel ? im really thinking it might be choke but i dont no what !
Old 20-04-12, 04:21 PM   #10
as far as i know the rear carb vacuum has branch for petrol tap which is vacuum operated so have a good check at those pipes. even the slightest hole will draw air in.
>K3 Intake Cams Skeletor Stuff Wanted 0 28-02-11 06:59 PM
Air intake SVMark SV Talk, Tuning & Tweaking 2 30-01-11 08:26 PM
Air intake question John 675 SV Talk, Tuning & Tweaking 9 08-01-08 12:20 AM
Air Intake! InvisableGeek SV Talk, Tuning & Tweaking 25 31-03-05 06:35 PM
Not oil leak - Petrol leak - double "Bugger"...! Potts SV Talk, Tuning & Tweaking 1 17-10-04 08:16 PM
