Old 23-04-12, 05:35 PM   #1
muzikill
muzikill's Avatar
Default Exhaust extraction in the garage?
Has anyone done anything like this? Waiting for the uk weather to hold up for at least an hour got me thinking how some jobs you need to run the engine so piping out the exhaust fumes in some way would allow me never to rely on the weather getting better. They do it in the main garages so what about home use?
Old 23-04-12, 05:37 PM   #2
Default Re: Exhaust extraction in the garage?
I tend to just open the door
Old 23-04-12, 06:18 PM   #3
cazzie
I've got an old cylinder vacume cleaner hose , which is a close fit over the exhaust 'spout' , which i've used for this very job for years, just poke the other out of a small gap in the door or window. Ideal for use in the winter or today !
Old 23-04-12, 06:37 PM   #4
The Guru
+1
Man up
Old 23-04-12, 06:59 PM   #5
porkyp
Excelent idea
Old 28-04-12, 11:26 PM   #6
Dabteacake
We use rubber hoses for the genes's at work. Only about 5ft long but bung into each other to add length just search eBay
Old 29-04-12, 08:06 AM   #7
Sy-superfly
Gas mask is easiest
Old 29-04-12, 10:26 AM   #8
punyXpress
punyXpress's Avatar
Run it on Castrol R & you wont mind the pong!
Now: Street Triple R
Old 29-04-12, 11:04 PM   #9
Originally Posted by Sy-superfly View Post
Gas mask is easiest
Before someone gets themself a darwin award... this won't work!
Old 30-04-12, 07:43 PM   #10
Sy-superfly
I've nearly got this award too many times
After a good garage for exhaust mcgrimes Pennine Massive 52 14-09-10 07:23 AM
What's the minimum size for a garage to be a garage? the white rabbit Idle Banter 3 20-12-09 08:39 PM
Humour extraction Dicky Ticker The Essex Lounge 17 10-07-08 08:01 AM
garage anna South & West Surfers 4 04-04-06 03:29 PM
Your Garage! DanDare Idle Banter 45 20-01-06 08:02 AM
