Hi all,
I have been reading up on a lot of threads with regards to jetting with certain combos etc of air and exhaust mods, for my project I will be running these setting: Velocity stacks (no filter just mesh) Open exhaust - still decided to go with seperate pipes for front and rear or a 2 into 1 like OEM What sort of jetting should I look at? Its not the most common setting to run! There will be 0 restriction of air getting to the engine as there won't be a fuel tank above it. |
Any airbox?
I guess 220
I'd suggest you might be better off with an airbox of some sort, it generally makes it a lot easier to get it to run right under all conditions, keeps turbulence away from intakes. As big a volume as you can make it.
An intake spout which gives no more than a nominal 50m/sec at max rpm won't restrict it at all. Work out the nominal air flow simply by 100% vol efficiency at max rpm, times swept vol divided by 2 (4 stroke, one cycle = 2 revs), then work out what intake area equates to 50m/sec. Put a 10mm flare radius on the entry.
Hmm ok, I will dig into working out the airflow then, I could be tempted to run a modded stock box with maybe a forward facing intake to push air into the air box - the sort of thing you can't really do on a bike due to the tank and frame being in the way lol
Don't forget with ram air you need to compensate the carbs for this, like feeding the bowl breathers to your "scoop".
Also a positive pressure fuel pump. No idea how much the stock vacuum operated jobbie can deliver.
The engine is on a kart, so I will be using a Mikuni pulse pump to deliver the fuel, if its not up to the job I will upgrade to something better, there are 2 carbs that need fuel rather than 1.
best wet tyre road / race? | nikon70 | SV Talk, Tuning & Tweaking | 4 | 23-11-11 06:58 PM |
race bike on the road | boo86 | SV Talk, Tuning & Tweaking | 7 | 19-05-09 05:05 PM |
MCN Fantasy road race | stewie | Idle Banter | 41 | 07-04-08 08:11 PM |
Race or Road? | joolzthomas | Exhausts | 8 | 17-06-04 08:29 AM |
a16 road n race | danpie | Exhausts | 0 | 24-05-04 12:21 AM |
