Old 01-05-12, 09:30 AM   #1
Epic Monkey
Default Pointy Stem Size?
Hey Guys.
I've bougth a GPS mount which uses the fork stem and has the 1" ball attachment thingy. What size do I need though?
- 13.3mm - 14.7mm (0.52" - 0.58")
- 15.0mm - 17.2mm (0.59" - 0.68")
- 17.5mm - 20.5mm (0.68" - 0.81")
Thanks.
Old 01-05-12, 11:39 AM   #2
Epic Monkey
Default Re: Pointy Stem Size?
Anyone? I need to tell the seller what size to send
Old 01-05-12, 11:49 AM   #3
What is the 'fork stem'?
Old 01-05-12, 01:51 PM   #4
Epic Monkey
Thought that's what it's called. It's this bit
Steering stem?
Old 01-05-12, 04:15 PM   #5
Epic Monkey
Scrap that picture. It's exactly the same as this but I cannot find the size anywhere.
Old 01-05-12, 07:17 PM   #6
Does that fit inside the end of the steering stem? If yes the dimension you need is the steering stem inner diameter. As you say it's the same as the second picture do you mean you have a different front end on your bike?
Old 01-05-12, 07:24 PM   #7
Epic Monkey
Yep. Fits inside the stem and has an expanding bolt.
Sorry. The second picture was just meant to show its location. I have standard pointy front end. I'd measure the tube myself but I'm waiting to get a bigger socket.
Old 02-05-12, 07:27 PM   #8
Epic Monkey
For anyone else looking. The correct term (in the Haynes manual) is the steering stem nut and the ID of the stem tube is 17mm.
Old 31-12-12, 02:30 PM   #9
Skybaba
I'm kind of in a similar situation and need some assistance.
I'm looking at buying a mount and case for the iPhone 5 and this mounts on the stem:
http://www.ultimate-mobiles.co.uk/mo...%20___2724.htm
The seller requires that I specify the stem size; he has the following:
13.3mm - 14.7mm / 0.52" - 0.58"
15mm - 17.2mm / 0.59" - 0.68"
17.5mm - 20.5mm / 0.68" - 0.81"
20.5mm - 24.5mm / 0.80" - 0.97"
Does anyone know what the stem size is for the Curvy SV650s Y (2000)?
Thanks,
Skybaba
Old 31-12-12, 02:44 PM   #10
LewSpeight
LewSpeight's Avatar
Thanks,
Skybaba
Can't help with the sizes but I certainly think you should give us some photos and a quick review when you get it, I'm looking at that particular thing myself
Steering stem top nut size? MisterTommyH SV Talk, Tuning & Tweaking 17 18-07-11 09:18 PM
Size Of Curvy Stem Nut? Aquila SV Talk, Tuning & Tweaking 14 08-02-11 03:04 PM
what size tank bolts do i need k3 pointy barwel1992 SV Talk, Tuning & Tweaking 11 21-03-10 01:45 AM
Whats the ehaust stud size for a pointy? DanF SV Talk, Tuning & Tweaking 3 15-05-07 12:39 PM
Quick one: What size tyres do I need for my pointy? thor SV Talk, Tuning & Tweaking 4 05-06-06 07:51 PM
