Old 11-05-12, 01:35 PM   #1
[etesv650
Default Exhaust hanger advice (scorpion street)
I bought this exhaust for my bike knowing that due to it being a 04+ exhaust I would need to make my own bracket or make a tab to connect the bracket with the rear footrest. However due to be link pipe and exhaust being welded into place its already very sturdy. Just want to know if a exhaust hanger is essential or if running without one is possible?
Thanks
Old 11-05-12, 01:54 PM   #2
Default Re: Exhaust hanger advice (scorpion street)
Generally speaking the can will spring about as you ride, this is a recipe for a cracked pipe. That said, the pipework itself is held at three widely spaced points, (both cylinders and the mount by the right footrest), and is thus quite rigid, therefore as long as it's a race can most of which are fairly light, rather than a silenced can which obviously will be much heavier, it will probably be OK.
Probably - keep an eye on it.
Old 11-05-12, 02:03 PM   #3
i would be tempted to make/buy a hanger bracket then make up a hanger plate and rivet/weld it to the can.
Old 11-05-12, 03:48 PM   #4
[etesv650
http://www.ebay.co.uk/itm/3804343876...84.m1423.l2649
I was thinking about getting something like this?. the garage that fitted the exhaust said it won't need a hanger however having one may put my mind at rest
Old 11-05-12, 04:14 PM   #5
SoulKiss
SoulKiss's Avatar
If the pic in the 1st post is your bike, you will also need the right-side pillion footrest to attach that strap to.
Old 11-05-12, 04:17 PM   #6
This
Old 11-05-12, 04:20 PM   #7
not unless he buys an exhaust hanger.
Old 11-05-12, 04:32 PM   #8
[etesv650
I have a rear pillion peg, just removed it as it didnt look the best having a hanger missing = p
Looking for some advice on the Scorpion Street Extreme. The Doc SV Talk, Tuning & Tweaking 4 09-03-12 04:43 PM
Scorpion Street Extreme Exhaust Girth For Sale - Other Bikes and General biking items 2 11-04-11 07:40 PM
New k9 sport - scorpion street extreme advice? ahmedf SV Talk, Tuning & Tweaking 9 13-11-08 07:54 AM
Scorpion Street Extreme Exhaust s.j.robson@bt Bikes - Talk & Issues 17 11-10-08 07:50 AM
Scorpion street extreme exhaust adw SV Talk, Tuning & Tweaking 4 17-08-07 07:20 AM
