Old 16-05-12, 02:15 PM   #1
Dave_es94
Default SV ignition, key stiff to turn on.
My SVs key thingy is very stiff and i can just about turn it on and putting the steering lock on is very hard, I found out if i wiggle it, it just about goes, Ive tried WD40 and hasnt changed much, how can i make it smooth to turn on off and parking lights only ect?
Old 16-05-12, 02:22 PM   #2
mister c
mister c's Avatar
Default Re: SV ignition, Key stiff to turn on
If you have both keys, just try the other one, your key could be worn
Old 16-05-12, 02:42 PM   #3
Dave_es94
Its alot better, still gets a little stuck going onto the sidelights only
Old 16-05-12, 04:16 PM   #4
NTECUK
NTECUK's Avatar
Default Re: SV ignition, key stiff to turn on.
Get the lead of a pencil and grind it up using an emry bord or simuler and work it in the lock .
Old 16-05-12, 04:39 PM   #5
widepants
widepants's Avatar
have you tried oil
widepants is offline   Reply With Quote
Old 16-05-12, 04:41 PM   #6
Originally Posted by widepants View Post
have you tried oil
Oil isn't recommend for lock barrels
As NTECUK suggested graphite powder is usually whats best
Old 16-05-12, 04:43 PM   #7
radicalry00
White lithium grease sorted mine out.
Old 16-05-12, 04:56 PM   #8
dry chain lube or graphite powder.
if you use anything liquid and sticky it will keep the dust inside the lock which adds to premature ware (turns into grinding paste). if you are having problems then blast some wd40 down then compressed air then lube with dry chain lube or graphite powder.
Old 16-05-12, 05:40 PM   #9
NTECUK
NTECUK's Avatar
Dont get grit or dirt in it .Oils grease will so avoid it.Just nick a pencil.
Old 16-05-12, 05:41 PM   #10
+1
'02 Blade - Turn Turn Turn... Won't Fire? JamesMio Bikes - Talk & Issues 21 07-10-11 06:27 PM
Ignition that won't turn off! madness SV Talk, Tuning & Tweaking 3 08-11-10 09:11 PM
Satnav for iPhone (Turn by Turn) Owenski Idle Banter 28 30-06-10 02:55 PM
Sticky key, difficult to turn in ignition barrel Maverick9999 SV Talk, Tuning & Tweaking 9 05-03-10 11:56 AM
SV650 Ignition wont turn to lock after wreck AFASTZ28 SV Talk, Tuning & Tweaking 6 30-08-05 06:37 PM
