Old 24-05-12, 08:52 AM   #1
ibby33
ibby33's Avatar
Default How important is tyre balancing?
How important is it to balance tyres, i had new tyres put on and i dont feel a difference
ibby33 is offline   Reply With Quote
Old 24-05-12, 11:13 AM   #2
MrMessy
Default Re: How important is tyre balancing?
Where they not balanced when the new tyres fitted? If the front is out of balance you will get a juddering at a certain speed.
MrMessy is offline   Reply With Quote
Old 24-05-12, 07:08 PM   #3
Depends, if you get lucky and it's all within 10g or so you'd have to go quite fast to notice the imbalance. Even faster to notice the same imbalance at the rear wheel.
The reverse is also true, try riding a bike that 40-50g off at the front - horrible.
Old 24-05-12, 08:40 PM   #4
AndyBrad
People in the past have told me it doesn't matter especially on the rear. I call ******** to that and say it is important. Although I agree the front us more important
Sent from my HTC Desire using Tapatalk 2
Old 24-05-12, 09:08 PM   #5
suzukigt380paul
have been told by a motor cycle shop owner who fits tyres that suzuki rims are normaly well balanced and dont need balancing and as to the tyres as long as they are fitted properly with the red spot at the valve there is hardly a need to do them,dispite that i got him to balance them
Old 24-05-12, 09:27 PM   #6
Most rims are fine no matter what bike, a few grammes at most - it's tyres that are off.
The balance mark is usually put next to the valve, but even then it can be way off, if it is break the bead and spin the tyre half a turn on the rim and try again - often significantly reduces the weight needed.
Old 25-05-12, 07:00 AM   #7
MrMessy
An experienced racer told me to balance the rim first then fit the tyre with the red dots to the heavy point.
Old 25-05-12, 08:38 AM   #8
-Ralph-
Shows how much crap gets banded about even by so called 'experienced' people. Tyres need balanced due to heavy spots in the tyre, rims should be pretty much perfect. Tyres are made of rubber in a mold, rims are metal and made to exacting tolerances. If you do have a slightly out of balance rim, what's the point in balancing it before you put an out of balance tyre on it? If it's going to need balanced at all then, he whole assembly needs balanced together.
Old 25-05-12, 09:04 AM   #9
MrMessy
Presumably if you find the heavy spot on the rim it apparently takes less weights to balance rim and tyre? We normally stick weights on with tape to start with so you do not end up with loads of weights stuck on.
Old 25-05-12, 09:15 AM   #10
-Ralph-
If the tyre is in the right place on the rim then yes, but other than a valve, why would you find a heavy or light spot on an undamaged rim?
very very important davepreston Idle Banter 0 08-01-10 02:39 AM
How important is...... petevtwin650 SV Talk, Tuning & Tweaking 9 26-04-08 07:35 PM
How important is wheel balancing and do racers do it? monkey Bikes - Talk & Issues 15 25-02-08 08:44 PM
Very important! Very important! Pedrosa Bikes - Talk & Issues 23 18-06-07 03:41 PM
Important Please Read Jelster Rideouts & Meetings 0 09-04-05 07:22 PM
