Old 09-06-12, 11:00 AM   #1
lawson17
Default Clutch switch bypass on Pointy?
Does anyone know a factual answer to whether bypassing the clutch switch on a K3 actually has any negative effects? I have read several articles, each conflicting the previous one!
If anyone has any more info it would be greatly appreciated.
Thanks.
Old 09-06-12, 11:34 AM   #2
flymo
flymo's Avatar
Default Re: Clutch switch...
The only negative effect is that you bypass a safety feature that is there to ensure you've got neutral engaged before you start the engine. If the switch is in good condition then no benefit in removing it.
Old 09-06-12, 11:47 AM   #3
TamSV
TamSV's Avatar
Is there some fuel map issue when bypassing the switch on the pointy?
Old 09-06-12, 11:49 AM   #4
flymo
flymo's Avatar
dont think so no, you may be thinking of the gear position sensor
Old 09-06-12, 11:56 AM   #5
lawson17
It currently doesn't have one you see, seems to work ok without. But have read several threads about it running on a 'neutral' map and lowering rev limiter... If this is true then I'll put a switch somewhere to mimic it... But I won't if it's not necessary.
Old 09-06-12, 12:33 PM   #6
flymo
flymo's Avatar
I stand corrected.... see here http://forums.sv650.org/showthread.p...76#post2617276
As K3 is a fuel injected bike the switch needs to be present. It appears the power loss will be minimal on a 650 but why bother?
Old 09-06-12, 02:14 PM   #7
lawson17
Ah! Good find. Thanks. I'll put a small switch on then. As the LH switchgear and connector isn't there anymore I'll splice it into the loom further back... Thanks.
Old 10-06-12, 05:08 PM   #8
flymo
flymo's Avatar
I'm not sure that simply splicing in a new switch is enough, otherwise shorting the switch connections would have achieved the same. My guess is that the operation of the clutch switch is sensed in a particular sequence in combination with the gear position sensor etc by the ECU.
Send Sv650Racer a PM on here or give Sarah or Steve a call at Steve Jordans, they should be able to explain how it works.
Old 10-06-12, 05:25 PM   #9
lawson17
I was planning on putting a switch on the handlebar, using during starting to ground the relay and give signal to ECU, then flick it off when she's all running... So it should be the same as the normal switch?
I'll give them a ring tomorrow, cheers Flymo.
Old 10-06-12, 06:59 PM   #10
flymo
flymo's Avatar
So why not just fit a standard clutch switch?
Clutch switch on K2 curvy 85jas SV Talk, Tuning & Tweaking 2 07-09-11 08:59 AM
disable clutch switch bald git SV Talk, Tuning & Tweaking 6 21-04-10 10:49 PM
Clutch switch Tony_BLY SV Talk, Tuning & Tweaking 3 20-05-09 07:20 PM
Clutch Switch duanedibly SV Talk, Tuning & Tweaking 21 15-02-08 03:04 PM
Clutch switch, is it needed? Razor SV Talk, Tuning & Tweaking 2 18-06-06 08:43 AM
