Old 20-07-12, 12:15 PM   #1
Default PC/TV/Monitor/HMDI question
I've got my PC monitor connected with a HDMI cable just now. I want my TV HDMI'd too so that I can have a dual monitor set up so I can drag over youtube etc to watch on the tv.
If I got a HDMI splitter would the pc recognise both monitors? Just now when I plug in the tv it knows it's a tv and sets the resolution etc and keeps the monitor as the primary display.
Also how do you send sound through the hdmi? When I have the tv connected the sound only comes on the pc speakers
Old 20-07-12, 12:24 PM   #2
Default Re: PC/TV/Monitor/HMDI question
no a splitter wont work as you sending the same signal, you need a twin HDMI card. or use HDMI for TV and DVI for monitor and toggle between the two but both will display the same screen
you cant send analogue sound down HDMI so you have to have a monitor or TV capable of decoding the signal.
Old 20-07-12, 12:30 PM   #3
I had the monitor on DVI and the tv on HDMI before which worked and let me have them as dual displays. But the DVI cable was too short so I bought a long HDMI for the monitor. Oh well guess I'll buy a long DVI cable.
So is there no way for the video card to send digital sound?
Old 20-07-12, 12:37 PM   #4
Viney
For the record, when i attach my HDMI from my laptop to TV, sound comes from TV
As for the HDMI spiltter, as said, no it wont work.
And for the cabling cabling4less is a cracking place.
Old 20-07-12, 12:38 PM   #5
hindle8907
hindle8907's Avatar
Use a DVI TO HDMI converter along with your existing HDMI cable for the monitor "you wont get sound to the monitor though"
and then use the normal HDMI for the TV.
The sound options should be under the mixer/sound options change the default device to use your card, what GFX card do you have ?
Old 20-07-12, 12:57 PM   #6
Cool cheers
Ahh right got the sound through the tv now. I can only set the default device though. Can't seem to have both on at once.
This is the card http://www.overclockers.co.uk/showpr...odid=GX-294-SP
Old 20-07-12, 01:10 PM   #7
hindle8907
hindle8907's Avatar
No its either one or the other unfortunately.
Old 20-07-12, 01:13 PM   #8
Damn. Oh well not that big a deal I guess. I'll get a DVI cable ordered
Cheers for the help everyone
TV as PC monitor tigersaw Idle Banter 23 31-01-10 11:50 PM
I need a TFT monitor metalmonkey Idle Banter 2 24-04-08 03:20 PM
monitor........ which one? hovis Idle Banter 25 30-12-07 07:10 PM
PC/monitor help hovis Idle Banter 9 04-11-07 08:54 AM
Monitor / TV Question Well Oiled Idle Banter 11 19-11-06 07:40 PM
