Old 21-07-12, 05:39 PM   #1
Thunderace
Exclamation Oil on tyre!
OK i had a bit of a disaster yesterday, dropped my toolbox in the driveway, landing bang on top of a can of WD40. Said can split and squirted oil all over my rear tyre, I managed to boot it across the lawn before too much came out, but I wiped the tyre down and later on took her for a spin, all is well until I drop the hammer in a bend and she slithers about a bit, nothing too alarming but any suggestions of how to get oil off? short of riding till I've scrubbed enough rubber off, I'm a bit concerned that when the rubber gets hot I'll have an oil coated rear tyre!
Old 21-07-12, 05:43 PM   #2
barwel1992
Default Re: Oil on tyre!!!
just wash the tyre down with soap or car wash soap
WD40 is not an oil as such
Old 21-07-12, 05:49 PM   #3
Thunderace
Yeah just spoke to a mate he said same, apparently soap breaks down oil? Cheers buddy!
Old 21-07-12, 06:01 PM   #4
barwel1992
yup it does if its quite a strong solution
Old 21-07-12, 06:37 PM   #5
Spank86
The soap molecules tend to surround oils and fats and lock them in to be washedmaway. it does mean you need quite a lot of soap compared to the volume of oil.
Old 21-07-12, 06:55 PM   #6
Dave-the-rave
Dave-the-rave's Avatar
Use fairy liquid.
SV650N K1
Dave-the-rave is offline   Reply With Quote
Old 21-07-12, 08:38 PM   #7
fenjer
I'd hate to see you panic when, mid ride out, you realise your Scottoiler* has dumped its entire contents over the back wheel...
*other chain maintenance systems are available apparently.
Old 22-07-12, 12:07 PM   #8
tonyk
tonyk's Avatar
Having a triumph which leaked oil since day one..........2 fxxxing years on
and still spitting oil. the best is to USE FAIRY LIQUID...............
it works !!!!!.
"Meh" - ASM Forever, RIP. 13/03/1986 - 05/04/2008
"Better to keep your mouth shut and appear stupid than to open it and clear all doubts."
Some days its not even worth chewing through the restraints...
tonyk is offline   Reply With Quote
Which tyre? Again. mabozzar SV Talk, Tuning & Tweaking 2 05-06-11 11:51 AM
Road Tyre Pressures and tyre problems G Bikes - Talk & Issues 14 05-06-08 03:29 PM
New Tyre Day Ch00 Bikes - Talk & Issues 2 03-04-08 06:38 PM
Tyre help for 1st tyre change! pencil shavings Tyres 11 10-07-07 09:55 AM
Q. When is a tyre not a tyre? Fearg Bikes - Talk & Issues 5 16-03-07 11:31 PM
