Old 23-07-12, 07:04 PM   #1
monkey
Default Roxter/Oxford heated grips. In case of any doubt.
My latest purchase. £38 delivered, new from ebay. Lovely. I believe these have the latest controller as opposed to the one pictured in the advert (picture below is what I received).
Old 01-08-12, 07:02 AM   #2
Heefy
Default Re: Roxter/Oxford heated grips. In case of any doubt.
Hi
Is the photograph in your post, from the seller, or what actually arrived? I am assuming they are Oxford, or identical to the Oxford Hot Grips. Is everything included as normal? Does it come with a mounting plate?
H
Old 01-08-12, 07:22 AM   #3
monkey
The picture is of what arrived and the plate can be seen on the right. There's a link in my first post to the advert.
I should have made it clearer that Roxter is the same as Oxford stuff but branded differently. I'd always been slightly sceptical until the grips turned up. They say Roxter on the grips but came with the Oxford controller. The link to the eBay advert will make it a bit clearer.
Old 01-08-12, 08:36 PM   #4
muzikill
muzikill's Avatar
Im having these. Local garage is selling these fitted for a ton
Sv fitting instructions wanted!
Old 01-08-12, 10:05 PM   #5
sputnik
The instructions that come with them should see you good as long as you are happy being linked up straight to the battery. I attached the control unit to the top yoke to the left of the ignition fwiw.
There is a illustrated/photo fitting guide somewhere (on this site i think) for oxford grips that is almost identical. These grips claim to turn themselves off if you leave them on and the battery charge gets low. This should avoid a dead battery. I can vouch for the fact that, certainly when it's v cold, they do switch off but there may not be enough charge left to start the bike! I can also vouch for the fact that bump starting on a damp frosty evening is bl#%dy impossible on bald oem tyres and the effort required in trying may make you vomit!
Old 01-08-12, 10:51 PM   #6
rigging up a simple SPST relay to the sidelight circuit will make sure that they off when ignition is off.
Old 05-08-12, 04:41 PM   #7
muzikill
muzikill's Avatar
Heres what arrived for me.
They'll do the job nicely. Dont know about using the 'superglue' to fit them to the bars though. Ive got renthal rubber glue (will the heat from these make it lose its tactility?)
Old 06-08-12, 01:23 AM   #8
monkey
How strange that we got different controllers!
Old 06-08-12, 11:40 AM   #9
muzikill
muzikill's Avatar
As long as it works. You got them fitted yet?
Old 06-08-12, 11:51 AM   #10
monkey
No. I've tested them and they work fine.
Roxter heated grips rob13 For Sale - Other Bikes and General biking items 0 02-10-11 03:05 PM
Oxford heated grips Nobbylad For Sale - Other Bikes and General biking items 2 09-01-11 08:10 PM
Oxford heated grips and symtec heated grips Alpinestarhero Ancillaries 18 25-01-10 04:43 PM
oxford heated grips again! Bunks Bikes - Talk & Issues 23 25-10-09 04:27 PM
oxford heated grips didge Photos 0 12-09-05 07:16 PM
