Old 26-07-12, 07:48 AM   #1
mcphillips
Default Knocking noise - Curvy.
HI all, New to biking have an w reg sv 650s and there is a strange knocking noise from the front of the bike in 2,3 gear around 20 - 30 mph. I had a mate who knows about bikes have a look for me and it seems fine. He can not take the bike out for a test ride as he came off on a track day and has broken ankles any help or advice where and how to check would be nice thanks.
oh when i pull clutch in the noise stops!!!
Old 26-07-12, 07:52 AM   #2
Elliott
Stiff link on the chain. Check, lube, retry if that doesn't solve the issue check for the link and either replace link or whole chain.
As for the pulling clutch that will be as there is no load on the chain.
Old 26-07-12, 07:54 AM   #3
mcphillips
Default Re: Knocking Noise
Cheers Elliott will have a little play and find out..
Old 26-07-12, 07:56 AM   #4
Elliott
No worries dude, any issues report back
Old 26-07-12, 08:44 AM   #5
daveyrach
Mine is doing the same, it's a T reg curvy, I know it's the chain though I haven't lubed it in ages. Will be doing that tonight.
Old 26-07-12, 08:46 AM   #6
Elliott
Bear in mind guys if the link is already stiff you are very unlikely to free it with lude, replacement is unfortunetly the answer.
Old 26-07-12, 08:54 AM   #7
mcphillips
Whats the long term damage and whats the score on using the bike?? Is it a safety issue
Old 26-07-12, 11:26 AM   #8
daveyrach
Mine tends to go away after a good clean and lube, I really should do it more often but that's me being lazy, I'm pretty sure mine is due for replacement anyway, I've had the bike 18months and done 10,000 miles in all weather, god know how many previous owner did on same chain and sproks.
knocking / clicking noise Big Bad Al SV Talk, Tuning & Tweaking 10 24-03-11 12:59 PM
knocking noise thedon1000 SV Talk, Tuning & Tweaking 22 13-10-08 08:27 PM
Knocking noise Cam_73 SV Talk, Tuning & Tweaking 3 04-08-08 07:48 PM
Knocking noise @ chain? skyline SV Talk, Tuning & Tweaking 22 07-04-08 07:40 PM
Clicking Knocking Noise ? mattglavin SV Talk, Tuning & Tweaking 12 10-09-07 03:09 PM
