Old 18-08-12, 09:50 AM   #1
daveyrach
Default DIY Tyre change?
What tools do need to change tyres on the SV? I can get the wheels off, are tyre levers enough?
Sent from my Samsung Galaxy S2 using Tapatalk 2
Old 18-08-12, 09:52 AM   #2
Default Re: DIY Tyre change
A spade, a couple of bits of wood, tyre levers & rim protectors
Old 18-08-12, 09:53 AM   #3
daveyrach
Explain? Lol.
Old 18-08-12, 10:37 AM   #4
I never managed to break beads with a spade.
Mavic I don't think you are any heavier than me I'd love to see a vid of you showing how it is done!
I break beads off in vice, or with improvised lever and back bumper of van/bracket on garage wall.
Then tyre levers. Then blow back onto beads with compressor (foot pump can manage most if no compressor), pump up, balance on axle stands.
Old 18-08-12, 10:41 AM   #5
YC you're right, I'd just quoted what I'd seen in Practical Sports bike
Davy, you place the wheel on the wood & place the spade edge on the tyre bead and stand on it. But with my puny 66kgs, YC is probably ight
Old 18-08-12, 10:43 AM   #6
Dabteacake
Could you not break the bead with 2 bits of wood and a G clamp?
Old 18-08-12, 12:26 PM   #7
Probably, need a big G clamp though.
You should probably pick more carefully where to repeat advice you haven't tried yourself, especially when the readers and writers are probably bearded 22 stone GSX1100 enthusiasts
Old 18-08-12, 12:46 PM   #8
Dabteacake
or strong forearms for the twisting lol
Old 18-08-12, 01:25 PM   #9
Don't think he was 22 stone, more like 20.5
Old 18-08-12, 04:39 PM   #10
speedyandypandy
2 big tyre levers and 1 small one is my preffered way, I don't bother with rim protectors, if your carefull and firm you will manage to do it without making a mark on them. A valve removal screwdriver thingy, soap(or sepcial tyre swapping soap/lubrecant thingy) it's easiest with a tyre breaking tool, but a piece of wood and a hammer works. When it's on 'bounce' the tyre sp it sets on the sides before you put air into it, do it without replacing the valve, more flow in better chance it sets first time. Let air out, replace valve, refill.
Then your ready to balance it or deliver it to a tyre/bike/car workshop.
Tyre - should I change it? SUPERSTARDJ01 Bikes - Talk & Issues 7 26-03-12 10:14 AM
A tyre thread.... For a change. Owenski Tyres 5 16-07-09 06:37 PM
tyre Valve Change? SV-net Bikes - Talk & Issues 11 08-04-08 05:14 PM
How not to change a tyre Stu Bikes - Talk & Issues 32 06-06-07 11:19 PM
Front tyre change The Mass Tyres 1 05-08-05 10:09 AM
