Old 21-08-12, 11:04 AM   #1
kevduncan
Default Exhausts - What happened in 2003-2010?
Howdie
I'm after a new can for my 2010 Sport model and there seems to be differing opinions as to what exhausts fit?
Some manufacturers list cans for 2033 and separate cans for 2004 onwards.
Some list them as 2003-2009 and nothing for 2010 onwards??
Whats going on?
What can I buy?
Thanks
K
Old 21-08-12, 11:10 AM   #2
timwilky
timwilky's Avatar
Default Re: Exhausts - What happened in 2003-2010?
99 - 2002 Curvy
2003 first pointy, high subframe
2004- still pointy but with a lower subframe
so I guess those saying a difference in 2003 and 2004 are really thinking about the hanger, pipework to keep things in line etc.
Not Grumpy, opinionated.
Old 21-08-12, 11:11 AM   #3
dr jekyll
hi
as far as im aware the were no differences between them ive used cans off a carby bike before now
i think it may be just the link pipes supplied
theres certainly plenty of choice out there
cheers
Old 21-08-12, 11:12 AM   #4
kevduncan
Ahh cool - so anything that's marked for use up to a 2009 should be cool for my 2010??
K
Old 21-08-12, 02:49 PM   #5
Runako
The 2010 bike is just when it was registered. I don't think Suzuki are still making SV's, just releasing old stock. So, yes 2009/2010 the same.
Old 21-08-12, 03:47 PM   #6
2003-2004 rear high subframe
2004-2007 rear low subframe
2007-present same as 2004> but with twin spark and lambda sensor so if you go full system you need bung for lambda. if you go slip on then same can/link pipe for 2003>
basically if its a slip on then any can/link pipe from a pointy SV650 will do although i'm sure that the scorpion street extreme link pipe is different for the 2003 but i got mine from a 2003 to fit a 2008.
word of warning: take the lambda probe out before you start cutting as they are delicate little things. don't be tempted to clean it either, just take out completely lay to one side and put back in when done.
SUZUKI SV650 2003-2010 Air Filter Brand New ian505050 For Sale - SV's and SV related items 4 23-05-12 09:53 PM
2003 Suzuki SV 650 K3 - Naked V-Twin (2003) adjblade For Sale - SV's and SV related items 10 05-05-11 03:12 PM
Delkevic Exhausts sv650s 2003 Stoneyginger SV Talk, Tuning & Tweaking 11 13-06-09 07:59 PM
pre 2003 / post 2003 sproket and chain adam_castell SV Talk, Tuning & Tweaking 1 22-02-07 03:01 PM
2003 GSXR 1000 headlight on 2003 SV footfukinmasta SV Talk, Tuning & Tweaking 0 22-01-06 08:27 PM
