Old 24-08-12, 06:40 PM   #1
199er
Default Brake failure?
Evening all,
Been browsing on here since I've owned an sv and I've decided to join and ask for some advice.
I have a 02 model curvy which is standard except one thing, which is good ridge lines.
After they were fitted I rode it and there were no problems, I didn't ride the bike for 2 weeks and when I took it Out again there was no front brake the lever drew all the way in without it stopping the bike.
After telling the mechanic who fitted lines what had happened he bled them for me which sorted the problem.
After leaving the bike for a week and a half the problem has come back no font brake again, could it just be that it needs bleeding again or is it something else?
Old 24-08-12, 06:43 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: Brake failure
Thats certainly not right at all.Take it back to the mechanic and get it looked at
Old 24-08-12, 06:44 PM   #3
Fruity-ya-ya
Talking Re: Brake failure
+1
And welcome to the org.
Old 24-08-12, 06:50 PM   #4
sv_rory
mine did that, it needed a new master cylinder
Old 24-08-12, 07:48 PM   #5
speedyandypandy
yes, mc draws air and pumps air into the system, happens more often than you'd think, but changing the whole thing is normally overkill, a service kit from wemoto should sort you out.
Old 24-08-12, 07:55 PM   #6
Thunderace
Yep the piston rubber on your master cylinder has likely split, service kits and new/second hand master cylinders should be roughly the same price on fleabay, I've just fixed same problem on my beasty and the m/c I bought was cheaper than a service kit but only by £4.
Old 24-08-12, 09:21 PM   #7
Steve
Steve's Avatar
yep me to, a master cylinder overhall kit from m&ps fixed it
Dreams & Screams go hand in hand
Steve is offline   Reply With Quote
Old 26-08-12, 03:53 PM   #8
199er
Default Re: Brake failure?
cheers for the advice guys got a service kit on order, rode it today it still brakes well but ive got more pull on the lever but the last time it failed the lever pulled all the way into the throttle and didnt have braking power the disc just slid through the calipers.
No harm in rebuilding the master cylinder though just to be safe.
Old 26-08-12, 04:47 PM   #9
speedyandypandy
Have the calipers ever been serviced? I would do that as well. Great difference.
Old 27-08-12, 09:53 AM   #10
sv_rory
I tried a master cylinder repair kit and it made no difference hence changing the whole master cylinder which was actually cheaper
MOT Failure JimmP SV Talk, Tuning & Tweaking 42 01-06-12 10:55 PM
MOT Failure? krhall Idle Banter 12 22-07-11 07:43 AM
MOT Failure melody Idle Banter 33 24-02-09 03:06 PM
Failure Dicky Ticker The Essex Lounge 14 30-10-08 08:52 PM
What a con! – MOT failure Blue_SV650S Idle Banter 30 25-05-07 07:11 PM
