Old 24-08-12, 07:15 PM   #1
alfa.rbt
Default Carb cleaning help please.
My cyrvy sv developed a very bad misfire so
- Ive checked spark plugs (1000m old iridium) and the sparking sweet against cylinder so guess leads are fine as well.
- might be a water in fuel tank and I'm yet to check that
Ive been told that it's going to be a dirty carbs so I want to take them off and clean them. Only problem is I never done that before and am afraid I might bugger something up soooo would anyone local be so kind to come around and supervise/advice me on sunday while I'm on it? I've got plenty of coffee and biscuts if needed. also i'll buy a case of favorite (enter your favorite lager, cider etc). I could give it to the garage but simply cant afford it and need a bike to go to work monday. I hope I'm not asking for much and will be very greatfull for help!!!
Old 25-08-12, 07:44 AM   #2
Jayneflakes
Jayneflakes's Avatar
Default Re: help needed!
Have you checked for rain contamination of the front plug lead first?
Then check for the condition of your spark plugs, how do the ends look, is one getting wet with fuel and earthing with out spark?
There are a couple of options to check before you dive in and take things to bits. Good luck.
Jayne you're a Pussy Magnet
Old 25-08-12, 06:57 PM   #3
alfa.rbt
cheers for advice, will crack on tomorrow morning with it. hopefully I'll find out whats wrong with my baby
Old 25-08-12, 09:06 PM   #4
Penry
I would but your a mission from me, try this http://www.youtube.com/watch?v=HeMjppADyTM but refer to the haynes for removal
Old 25-08-12, 09:08 PM   #5
DJ123
DJ123's Avatar
when did it start mis firing?
BMW F800ST
Old 25-08-12, 09:14 PM   #6
alfa.rbt
Few days ago after I fitted new battery as the old one died.
I didn't ride it in the wet recently, use same fuel station all time ( shell vpower if that matters)
Old 25-08-12, 09:15 PM   #7
alfa.rbt
Cheers mate
Old 25-08-12, 09:17 PM   #8
DJ123
DJ123's Avatar
did you check the spark plug gaps? is the air filter clean?
BMW F800ST
Old 25-08-12, 09:29 PM   #9
alfa.rbt
Would the gap change it self?
Air filter looks clean.
Misfire is actually happening at about 6k revs when engineis worm and about 2.5k when cold. Also when it's cold and start misfiring at 2.5k it dies. When at idle it runs fine. Also when on full choke it's at over 3k revs it does not misfire even wyen cold, only when I touch the throttle. Don't know what else to say
Old 25-08-12, 09:35 PM   #10
DJ123
DJ123's Avatar
Is the air box sat down correctly, seated & sealed well, no air leaks getting into the system?
BMW F800ST
Carb Cleaning MacDaddySV SV Talk, Tuning & Tweaking 4 28-07-11 08:33 PM
Carb Cleaning: MrMessy SV Talk, Tuning & Tweaking 2 30-05-11 10:04 PM
Carb cleaning - how? lechatenetpat SV Talk, Tuning & Tweaking 4 26-08-10 10:56 AM
Carb Cleaning went wrong :/ dazzaboy SV Talk, Tuning & Tweaking 8 08-08-10 07:35 PM
Carb Cleaning mattglavin SV Talk, Tuning & Tweaking 4 29-10-07 12:29 PM
