Old 02-08-10, 07:09 PM   #1
dazzaboy
Default Carb Cleaning went wrong :/
took carbs off yesterday to clean and discovered the mixture screw on front carb to be seized and now rounded nyone got any ideas or a set of carbs for sale? thanks
Old 03-08-10, 07:26 AM   #2
Warthog
Default Re: Carb Cleaning wen't wrong :/
try looking in the for sale section, or advertising in the wanted section. As for ideas, I wouldn't listen to me .
Old 03-08-10, 07:33 AM   #3
Viney
They all do that sir, dont worry about it, mine have been stuck for years and it runs fine, unless yours doesnt. I really wouldnt worry about it.
Old 03-08-10, 12:09 PM   #4
thedonal
Or you can get them drilled out and a new set put in?
One of mine is seized. It hunts a bit at idle. I'd like it to be purringly smooth (especially for the cold starts due in a couple of months...). I will be visiting Stewart and Bill at some point to get it sorted (probably around service time- Septemberish).
Old 03-08-10, 07:15 PM   #5
dazzaboy
mine dn't run right tho so i don't have a choice lol they still run rough so balancing was next option
Old 03-08-10, 07:25 PM   #6
balance is far more likely to be issue than mixture. fact that the screws are seized means the mix can't change that much unless something else is wrong.
Old 03-08-10, 07:46 PM   #7
hardhat_harry
Got a set for sale in really good condition have a look in for sale.
Old 04-08-10, 07:23 AM   #8
Viney
I can only confirm Yorkies comments, more likely the balancing than anything. My mixture hasnt been changed since about 2002, the carbs however, have been balanced about once a year
Old 08-08-10, 07:35 PM   #9
daz_ash
Default Re: Carb Cleaning went wrong :/
i got 2 sets for sale if ur intrested of 99-02 curvey
Wanted: Clocks for carb model naked + headlight and carb. Gazdaman Stuff Wanted 2 17-03-10 03:50 PM
Carb Cleaning mattglavin SV Talk, Tuning & Tweaking 4 29-10-07 12:29 PM
When wearing high heels was wrong, so wrong... Razor Idle Banter 6 03-06-06 08:51 AM
Solvent for cleaning and soaking carb bits please petevtwin650 SV Talk, Tuning & Tweaking 11 23-05-06 02:42 PM
Wrong Construction wrong colour . amarko5 Bodywork 12 30-10-04 03:23 PM
