Old 22-05-06, 02:34 PM   #1
petevtwin650
Default Solvent for cleaning and soaking carb bits please
Got myself a Factorypro carb recal kit at the BMF, so I'll be dismantling my carbs. They need a good clean anyway as the bike had only done 1100 in four years before I got it.
Can anyone recommend a solvent to soak the carb bits in to clean all the gunk off.?
Incidentally the carb kit comes with 3 sets of jets, 2 needles and clips, plus new stainless bolts for the tops and bottoms of the carbs. £66. A dynojet set is about £80 isn't it, and I don't know if you get new screws or not.
Old 22-05-06, 03:18 PM   #2
chazzyb
Carb cleaner might be a good one to try.
Old 22-05-06, 03:56 PM   #3
petevtwin650
Does what it says on the tin
Really looking for something to soak bits in too, as I imagine they'll be pretty manky.
Thanks
Old 22-05-06, 04:07 PM   #4
Viney
in my experience, carbs just really get dirty on the outside. The screws get pretty naffed up if you are not careful undong them, other than that, theres not a lot else that really screws up, unless you use crap petrol.
the jetsm needles etc are pretty good though, as the needles wear overtime. I use Wurth electrical contact cleaner. Its fantastic stuff. Carb cleaner is also good.
Old 22-05-06, 04:12 PM   #5
chazzyb
I filled an old ice cream tub (a oval smallish one) with the contents of a carb cleaner spray can and soaked carb bits. I believe you can buy all these wonderful solvents in 5 litre tins if you look in the right place (I haven't yet). Just make sure you've got the windows/doors open and scarper pronto if you feel slightly odd.
Old 22-05-06, 04:19 PM   #6
petevtwin650
It's not dirt I'm worried about Viney but the deposit left by stale petrol that there is bound to be on my carbs. I;ve used carb cleaner that you add to petrol and that defo improved things, but a strip is required I reckon especially as I've got the new needle and jet kit.
Yeah I was gonna fill a glass jar with a tin of carb cleaner contents, but figured there had to be a cheaper easier way Chazzyb.
Old 22-05-06, 04:28 PM   #7
Smiffy
Fresh petrol!
Old 22-05-06, 06:27 PM   #8
longer
Hey Mate,
You can use acetone, it is a bit hard to get hold of in the UK but works well. Just don't put rubber seals in it. They will dry out and fall apart.
Old 22-05-06, 06:34 PM   #9
Carsick
Isn't nail varnish remover sometimes acetone? or what about some paint thinners?
Old 22-05-06, 06:53 PM   #10
Robw#70
Caustic soda crystals is best, Just the cheap stuff from hardware shop, dont mix it too strong, but only on the brass, alloy tends to make a fizzy mess
Carb Cleaning mattglavin SV Talk, Tuning & Tweaking 4 29-10-07 12:29 PM
What is a High Flashpoint Solvent 2mths SV Talk, Tuning & Tweaking 23 22-06-07 08:24 AM
where to buy acetone (or other fiberglass resin solvent/cleaner)? weazelz SV Talk, Tuning & Tweaking 6 08-05-07 09:09 AM
Arrrgggggggggghhhhhhhh - Soaking Wet Hands I'm_a_Newbie Bikes - Talk & Issues 18 23-10-06 08:54 PM
what solvent and sealant? lukemillar SV Talk, Tuning & Tweaking 7 11-09-06 04:44 PM
