Old 27-08-12, 02:05 PM   #1
dirtyred619
Default Help! Someone else has (possibly) screwed up the shock bottom bolt!
Finally got round to (trying) to fit my rear shock this morning (well it has been bank holiday weekend).
All was going well, got the bike hoisted up etc and then I got to what I thought would be the easy part, undoing the 3 bolts holding the shock in. They didn't want to undo.
Now it looks like the bike has had a different shock in in the past which is fine but whoever put the old shock back has put the bolts in from the left so the nut is over by the exhaust. They then recruited Zeus and a gorilla to tighten everything together whilst coating the nut and bolt in what I'm assuming was araldite or similar.
So basically has anyone any suggestions on the best way off loosening them, I'm scared off rounding the bolts off and making things even harder? It also didn't help that I was trying to do the swap myself.
Old 27-08-12, 02:07 PM   #2
Paul the 6th
Paul the 6th's Avatar
Default Re: Help! Someone else has (possibly) screwed up the shock bottom bolt!
That's it... I'm not letting hongman anywhere near my bike.
Old 27-08-12, 02:14 PM   #3
Good quality single hex sockets, possibly heat.
Old 27-08-12, 02:15 PM   #4
Elliott
Angle grinder, cut the head off and replace the bolt
Old 27-08-12, 02:17 PM   #5
DJ123
DJ123's Avatar
All bolts on the shock and lower assembly are mount to be inserted from the left, that's no mistake. Do you have good quality sockets that fit the bolts and nuts tight. You only need a spanner on the nuts to 'hold' them, the bolts unscrew from them. Make sure you have good leverage on a decent 1/2 inch ratchet/power bar.
BMW F800ST
Old 27-08-12, 02:20 PM   #6
Better to hold bolt and undo nut, less friction and bigger hex...
Old 27-08-12, 02:24 PM   #7
dirtyred619
Probably easiest as I'll be using a different bolt but I've no angle grinder.
Old 27-08-12, 02:26 PM   #8
Elliott
Think I've got a dewalt one somewhere.
Ride down and do it here?
Old 27-08-12, 02:27 PM   #9
dirtyred619
Now I'm not saying you are wrong but it would make sense to me to insert bolt from right and have the nut on the left as access is slightly easier on that side.
Also in the below thread everyone seems to turn to on shock swaps, it also says bolt in from the right with nut on the left.
http://forums.sv650.org/showthread.p...r+shock+pointy
Can anyone confirm the correct way off putting the nut and bolt in, if there is one?
Old 27-08-12, 02:29 PM   #10
Elliott
either way doesnt matter, suzuki choose to go from the left
Help, I've screwed up the bottom shock bolt hongman SV Talk, Tuning & Tweaking 123 06-09-12 04:28 PM
ZX9 or 10 bottom suspension bolt DaveW_42 Stuff Wanted 0 21-05-10 11:29 AM
K5 gsxr thou shock going onto k5 pointy - will I need the lower gsxr shock bolt? Paul the 6th SV Talk, Tuning & Tweaking 37 31-10-08 12:26 AM
M10 55mm Shock bolt and nut for Kwak Shock Mr Speirs Stuff Wanted 3 24-10-08 12:00 AM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
