Ancillaries Post your own reviews, opinions and experiences on various other bits and bobs, such as rearsets, oil, engine bits.
Old 11-09-12, 08:15 AM   #1
cabra
Default HID Lighting Upgrade
Has anyone fitted an HID Bi-Xenon lighting kit to a "curvey"? Fed up listening to "hear-say" horror stories!! First hand experience/knowledge feedback would be much appreciated.
Old 11-09-12, 08:40 AM   #2
NTECUK
NTECUK's Avatar
Default Re: HID Lighting Upgrade
http://www.hids-direct.co.uk/suzuki-...onversion-kit/
H4 kit.
Cheap e bay ones are a lottery
Ps select 4600k as its a better real world light same as oe hid s are.
Old 12-09-12, 09:28 PM   #3
P-J
Got one fitted to my Gixxer!
IMO...Brilliant bit of kit if for nothing else making you more visible! If you have reflector lenses it has been suggested that you get H-R/RM bulbs! As NTECUK said no point going over 6000k as you loose the the brightness!
Good luck
PJ
Old 12-09-12, 11:10 PM   #4
Joe Marcon
I have one but alot of people flash at night thinking i have full beams lol
Old 12-09-12, 11:56 PM   #5
NTECUK
NTECUK's Avatar
Set it lower line on a beam setter .
Old 13-09-12, 08:37 AM   #6
Dipper
Dipper's Avatar
I've had the cheap ebay ones fitted for a couple of years now. I agree with NTEC I initially went for 6000k but found the light poor (too cold) for unlit lanes have now changed to 4300k which I find perfect for what I want. They are much better than halogens giving a wider brighter spread of light, you will need to adjust the beam height as it will differ from when halogens are fitted, I used the masking tape on a wall method and get no problems with oncoming vehicles being blinded. Seems to sail through the MOT..... so far!!!!
Dipper is offline   Reply With Quote
Old 13-09-12, 08:54 AM   #7
cabra
Thanks peoples, PITA to fit? whole front end strip I suppose?
Old 13-09-12, 09:59 AM   #8
NTECUK
NTECUK's Avatar
Not much more than n changing a normal bulb ..
If your not too stiff and can work in tight spaces your not have to take much off.
The ballast needs a 12v supply and ground.keep it out of the rain but get air around it.
Old 13-09-12, 01:14 PM   #9
got the cheep ones off ebay 2x50w bi-xenon 5000k and they are the doggyzz doooodddaazzz. angled down a bit as i was getting a few flashes (but not that many) but now i get none. its nice having daylight in front of the bike
Old 13-09-12, 01:52 PM   #10
Fozzy
Got a link biobo pls?
Sent from my GT-I9100 using Tapatalk 2
Garage Lighting daveyrach Idle Banter 21 27-01-12 11:42 AM
Aux lighting. rictus01 Bikes - Talk & Issues 3 13-02-09 02:08 PM
HID lighting upgrade Ed Bikes - Talk & Issues 26 26-01-09 09:51 PM
HID lighting erics02 Bikes - Talk & Issues 28 26-10-08 08:33 PM
HID lighting the_lone_wolf Bikes - Talk & Issues 71 02-07-08 04:48 PM
