I would imagine a fairly long time,as in years. Without the acid the plates /cells have nothing to react with. Kept lorry batteries like this[dry] for a couple of years without adverse affect.
thanks DT.
Indeed, they'll last for many years. If it's a wet battery that's already seen some use then make sure it's fully charged before draining the electrolyte or it'll crap up the chemistry when you fill it again. You could even rinse the cells out with some DI water before storage then get some fresh acid in when you're ready to go!
Can a loose battery terminal prevent the battery from charging while being able to crank the engine? | maxinc | Bikes - Talk & Issues | 5 | 22-07-11 02:59 PM |
SAS storage | ThEGr33k | Idle Banter | 13 | 17-08-10 02:24 PM |
Optimate battery charger drains the battery | flymo | Bikes - Talk & Issues | 10 | 10-06-09 10:41 AM |
Battery/Starting problem - new battery hasnt fixed it! | Aaron | SV Talk, Tuning & Tweaking | 13 | 24-01-05 05:21 PM |
