Old 20-10-12, 07:59 PM   #1
podrikk007
Default Can't get into neutral when cold
Not sure if its a common thing or what, but I seem to always click straight past neutral, I click it the tiniest bit, and it jumps past it. Anyone know what the prob could be? Thx
Old 20-10-12, 08:04 PM   #2
muzikill
muzikill's Avatar
Oil level. Clutch adjust. Sprocket minging. Chain adjust.
I had this for a while. I realised i was hard changing gears so finding neutral was difficult. Feel too clicky? Time to give the whole mech a service.
Old 20-10-12, 08:22 PM   #3
podrikk007
I was thinking about attempting a full rebuild over winter but may be a bit too technical for me
Old 20-10-12, 09:34 PM   #4
muzikill
muzikill's Avatar
You thinking its more difficult than it is. There a very famous clutch adjust thread in these forums and i suggest you try that first and make sure the oil level isnt too high or low.
Old 20-10-12, 09:35 PM   #5
podrikk007
I will try that, thanks
Old 20-10-12, 10:34 PM   #6
Jammy
Default Re: Can't get into neutral when cold
Do as muzikill suggests. I solved this issue by draining some oil from the crankcase (by loosening the filter) so the level was was sitting halfway between Full and Low... I also adjusted the clutch at the engine end and now it all works fine
Old 20-10-12, 11:43 PM   #7
it can also be the simple answer and that is the gear shift pivot is needing lubed.
Old 21-10-12, 01:31 AM   #8
Spank86
All my bikes go into neutral all the time even when I don't mean them to.
It's cos I'm sloppy with my clutch work.
Finding neutral when cold. hindle8907 Bikes - Talk & Issues 5 25-06-11 09:27 AM
Where's neutral? Geodude SV Talk, Tuning & Tweaking 20 01-07-09 07:16 PM
Won't go into neutral veraliar SV Talk, Tuning & Tweaking 7 01-02-07 07:05 PM
Finding Neutral DanDare SV Talk, Tuning & Tweaking 11 17-05-05 11:38 AM
Neutral Wiltshire7 SV Talk, Tuning & Tweaking 21 17-01-05 04:41 AM
