Old 21-10-12, 07:46 PM   #1
Dave_es94
Default Sv650 horn fails when hot.
650 horn fails when it gets hot, Any ideas on how to stop it failing, e.g a better place to mount it?
Old 21-10-12, 07:51 PM   #2
Mark_h
Mark_h's Avatar
Default Re: Sv650 horn fails when hot..
I got fed up with a feeble beep which then stopped when the rad got warm so I fitted a pair of fiams and used the original hooter feed to drive the relay for the new horns. The relay fits nicely between the front of the airbox and the frame and the original hooter feed will pull back.
The twin Fiams from Halfords come with mounting hardware and the relay for 15 to 20 quid.
Minister for Sustainability
Old 22-10-12, 11:56 AM   #3
MJC-DEV
MJC-DEV's Avatar
You could also try backing off the adjusting screw on the back a little.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 22-10-12, 12:07 PM   #4
Dicky Ticker
Give the internals a good spray with WD40.
Old 22-10-12, 12:15 PM   #5
jambo
jambo's Avatar
If the mounting is too close to the radiator it can get overly hot and stop working. Sometimes simply bending the bracket a little is enough to correct the fault, but replacing or relocating the horn would also work.
Jambo
Old 23-10-12, 12:05 PM   #6
Nobbylad
Nobbylad's Avatar
One of the first mods I did was replacing the useless stock horn with a Stebel Nautilus.
Cheap (<£20) and easy mod that makes oodles of difference.
Old 23-10-12, 07:08 PM   #7
5hort5
mmm think they have gone up in price a bit, cheapest i can find is 35 quid on ebay. shame, i'll maybe add it to the christmas list.
5hort5 is offline   Reply With Quote
Old 25-10-12, 03:45 PM   #8
Mark_h
Mark_h's Avatar
I use these they sound like a truck and make the MOT test guy jump each year
Old 26-10-12, 12:30 PM   #9
Jayneflakes
Jayneflakes's Avatar
I moved my horn to the fork leg and added a little extra wire to allow for the reach. It always works and is not hidden out of the way, which also helps make the horn a little louder.
Jayne you're a Pussy Magnet
Old 26-10-12, 01:04 PM   #10
Fozzy
Links? I can't find any!!
Sent from my GT-I9100 using Tapatalk 2
Leicester learner driver fails theory test 92 times metalmonkey Idle Banter 11 27-01-12 10:27 PM
Aussie anti-immigration MP migrates to UK, fails to see irony... the_lone_wolf Idle Banter 9 15-02-10 03:53 PM
Best fails of 2009 wyrdness Idle Banter 15 08-01-10 09:46 PM
Epic AR fails missyburd Photos 26 17-07-08 11:14 PM
Rossi fails on four wheels again! Mariner Bikes - Talk & Issues 7 02-02-06 08:03 AM
