Old 06-12-12, 09:03 AM   #1
RogerNeville
Default Curvy Ignition Fuse Blowing - Carb Heaters.
Firstly, thanks to all the contributors who've helped in the past with various issues on my SV, (Naked Curvy 20002). Much appreciated.
I've had a spate of ignition fuses blowing, after a mile or so. After reading the forum I irrationally decided to change the Starter Relay as this seemed to be a common cause...Nope. Then I found the often quoted loom chafing under the tail section left hand side, stripped it back, re-covered with tape. Ahhh! Still blowing. Now blowing as soon as ignition key switched on. So after a long session with the Multi-meter I found that the wiring to the Carb heaters has a full earth. The connector for this is found under the Fuel Tank, right hand side. It has two wires, Orange with yellow banding & Black with white banding. Disconnected the thing and hey presto! All ok now, not sure if the carb heaters perform much of a function as the ride to work this morning was bloody cold, -2, although it's only a 10 mile commute. Soon see I guess.
Old 06-12-12, 09:09 AM   #2
Default Re: Ignition Fuse Blowing - Bloody Carb Heaters
Nah be reet. They are meant to stop carb icing but not too effective. I ran without them for ages.
If you get carb ice (some do some don't, no rhyme or reason), you are better off dosing the fuel with a bit of isopropanol.
Old 06-12-12, 12:35 PM   #3
rb8989
I didnt even know the sv had carb heaters! Last time I saw one of those was on my 89' vw polo carb! It was removed when I fitted a K&N stack and still starts fine.
Old 06-12-12, 03:25 PM   #4
RogerNeville
Cheers Chris, had an idea they didn't do much. Thanks for the tip, appreciated.
Carb heaters and wiring 2002 K3 curvy tomskthewomble Stuff Wanted 0 27-06-12 02:06 PM
Ignition fuse blowing: clutch switch? ChrisCurvyS SV Talk, Tuning & Tweaking 0 09-01-12 07:08 PM
Fuse keeps blowing benjyman Bikes - Talk & Issues 10 03-06-09 12:52 PM
Ignition Fuse blowing Frogman SV Talk, Tuning & Tweaking 7 16-04-07 05:57 PM
ignition fuse keeps blowing any ideas adey SV Talk, Tuning & Tweaking 6 06-06-06 04:22 PM
