Old 19-12-12, 11:52 AM   #1
JonGeorge
Question Supporting bike with no forks?
I need to remove the forks on my naked curvy but I dont have access to a garage, I have an outside space dedicated for my parking is there anyway of removing them and keeping the bike where it is? HEELPPP
Old 19-12-12, 12:01 PM   #2
Grant66
Grant66's Avatar
Default Re: Forks
Is that on-street (or semi public car park)? My Curvey sat for a weekend (admittedly on my drive) with a the front forks off supported with a couple of bricks and bit of old skirting board under the sump. Survived a wheely bin incident with out any issues.
What is your concern?
Formerly known as Gajjii
Previous Bikes: Red Sk1 Curvy, Red MT-07.
Current Bike: Black MT-09.
Grant66 is offline   Reply With Quote
Old 19-12-12, 12:06 PM   #3
JonGeorge
Default Re: Forks
No its an 'almost' private car park only the four residents including me use it there's plenty of space, seems a good idea! I'll be using your idea. Did you loosen up all the fork bolts before you jacked it up on bricks? My fork oil seals are leaking big time ..its even seized my front brakes!
Old 19-12-12, 03:44 PM   #4
Dicky Ticker
Default Re: Supporting bike with no forks?
With regard to the above header---
I no longer have an SV but I still have a set of stand I made up for this sort of maintenance. They are designed to sit under the crash bungs and ideal for any front end work or general work where you want the bike upright and can be used with a rear paddock stand to completely lift the bike off the ground.
Free to anybody who wants to collect them from Essex
PM me for details
Old 19-12-12, 09:50 PM   #5
Grant66
Grant66's Avatar
Didn't need to no.
BTW if your stripping the forks don't forget to loosen the bottom bolt (the one holding the damper rod in place that you can't see when the axle is in) before removing the forks, you can loosen it later if you have a handy vice.
Old 20-12-12, 10:56 AM   #6
JonGeorge
PM me for details
I'm working in Dagenham/Rainham after the new year. Would it be possible to pick up? Thanks btw
Old 20-12-12, 07:02 PM   #7
Dicky Ticker
Yes,they are to heavy to take on the bike ,you will need a car but are welcome to them.
Old 20-12-12, 07:17 PM   #8
You've got the solution to your problem from DT
For future work buy an ABBA stand and this will be so useful for jobs on both ends of the bike, especially as you don't have a garage.
When using an ABBA stand on front end work, you just need something under the engine to stop it tipping forward
http://www.abbastands.co.uk/
Old 22-12-12, 03:10 PM   #9
mikerj
Default Re: Forks
How has fork oil managed to seize your front brakes? Are you sure the calipers aren't simply corroded, as this is a common issue?
supporting bike without stand? curvy custard SV Talk, Tuning & Tweaking 56 01-02-11 12:46 AM
an england football team worth supporting davepreston Idle Banter 2 13-08-10 04:03 PM
P&H are supporting ‘PUSH TO FREEDOM’ providing assistance to injured service personnel kirsteenshort Rideouts & Meetings 0 20-07-08 09:26 AM
Supporting the SV Binky SV Talk, Tuning & Tweaking 3 12-07-08 03:54 PM
euro 2008 who are you supporting hovis Idle Banter 50 29-06-08 09:02 PM
