Old 11-01-13, 09:51 PM   #1
sniff
sniff's Avatar
Default Brake light pressure switch?
Can anyone explain how I fit or use one please?
I;ve got DanMoto ones at the moment but these feelcheap and nasty and want to swap for something a bit more robust. But have no idea on the pressure switch thing for rear brake.
Going to get the GB Moto ones £150 but only as I know they guys.
sniff is offline   Reply With Quote
Old 12-01-13, 02:32 AM   #2
LewSpeight
LewSpeight's Avatar
Default Re: rear set pressure switch
Linky to these GB moto ones? I cant help with the pressure switch thing, but kinda glad you commented on the Danmoto ones, i was after them myself.
Guess not now though
Old 12-01-13, 08:53 AM   #3
Runako
I have got both a pressure switch or 'brake light switch' for a GB Moto rearset and some second hand rearsets for sale.
Someone else posted this elsewhere:
(Assuming the brake side originals have been removed)
1) Replace the banjo bolt (the top most bolt on the master cylinder) with your new banjo bolt pressure switch.
3) Use wire cutters to cut the end of the stock brake light switch and then use those same cutters to strip the tubing off so that you have access to the copper wire.*
4) Take the copper wire from each section and spin it or however you like to keep it straight.
5) Use pliers to squeeze the copper connectors together and then connect it to the wiring from the stock wires before attaching the wiring to the pressure switch.*
6) Turn on the battery (do not turn over), apply rear brake to test connection.
7) If necessary use electrical tape to cover any exposed wiring including the new banjo bolt before bleeding the brakes etc and re-assembling rearsets.
* I can't remember if the GB Moto ones require splicing and dicing or if they have a ready made connector (will check later) but the principle is the same. Its fairly straightforward to do.
Here are the used rearsets for sale along with some other items:
http://forums.sv650.org/showthread.php?t=188917 (Pics uploaded)
Old 12-01-13, 11:49 AM   #4
sniff
sniff's Avatar
These are the GB Moto ones. Dan Moto are really comfy but the very long gear selection rod bent after only a 100 miles. Seems to long and too soft for the job. They are sending my a new one. Think I'll sell them and get the GB ones instead.
http://www.ebay.co.uk/itm/GBMOTO-REA...item1e6fdb6dad
Old 12-01-13, 11:53 AM   #5
sniff
sniff's Avatar
Think I might just have that pressure switch off you. The rear sets I'll have to buy almost the whole lot. Thanks but I'll get brand new ones instead.
Old 12-01-13, 12:08 PM   #6
Runako
If you're getting it direct from GB Moto they do supply the pressure switch (not to kill my own sale or anything )
Old 12-01-13, 12:50 PM   #7
the pressure switch usually comes with bullets on them or at least mine did. i can make up 'gender changers' to save you hacking the bike loom or old brake light switch.
Old 12-01-13, 09:01 PM   #8
leebex
I had to buy a new pressure switch from gb moto recently for my rearsets, very good service from them. Mine had no connectors of any sort just bared ends for crimps of my choice. was about £12.
Old 12-01-13, 09:05 PM   #9
leebex
its these:
http://www.gbmotoracingparts.com/gbm...1000-159-p.asp
K6 rear brake light pressure switch. leebex SV Talk, Tuning & Tweaking 11 23-11-12 09:55 AM
Rear brake pressure switch Nobbylad SV Talk, Tuning & Tweaking 2 22-08-12 04:00 PM
Brake light switch sticking on with front brake rick0361 SV Talk, Tuning & Tweaking 6 11-06-09 06:20 PM
Front brake light switch svrash Stuff Wanted 0 21-03-07 11:01 AM
Rear brake light switch dirtydog Stuff Wanted 4 29-12-06 08:50 PM
