Old 15-01-13, 02:40 AM   #1
bellisan
Default Homemade heated vest controller?
I just got a hand-me-down heated vest. It has no controller. I looked at the site and they are available, but I don't want to spring for the $70.- for it. I could bodge up a really Neanderthal resistance based controller, but they end up dissipating power in the added resistors. So I was thinking that I could do something micro-controller based that would control the heat by varying the duty cycle. I should be able to use some power transistors as a switch and they would not dissipate much power, or I could go with a relay based solution. I was also thinking that I could incorporate a thermal sensor and create a feedback loop. Issues: my EE skills are poor at best, software is what I do. Anyone have any pointers or suggestions?
Old 15-01-13, 06:48 AM   #2
punkyp
Default Re: Heated vest controller
Research pwm controllers.
Old 15-01-13, 10:29 AM   #3
Default Re: Homemade heated vest controller?
I'd use an atmega328
Link the ADC to a variable resistor or some sort of lo-hi-off 3 way switch, then one or two mosfets to control it through pwm
You might also want to look at arduino, it's a slightly higher level programming language. I've been using C for some diving stuff and to be honest it's giving me indigestion. By the time you've finishd you might wish you'd spent the $70... will be fun though!
Old 15-01-13, 10:31 AM   #4
Mark_h
Mark_h's Avatar
Or just have a switch. If cold torn to -On. If warm enough turn to - Off. Replace with a thermostat inside the jacket if you find you are turning it on/off too often. Or are the elements so powerful you'd end up basted?
Minister for Sustainability
Old 15-01-13, 03:32 PM   #5
keith_d
keith_d's Avatar
Sounds like vast overkill for a heated vest. Just use a variable duty cycle oscillator (ICM7555?) and a high current FET switch. If you're not warm enough turn up the duty cycle.
Old 15-01-13, 03:35 PM   #6
That would probably be a better and cheaper alternative
I should add the caveat to my earlier post "I know nothing!"
Old 16-01-13, 06:34 PM   #7
bellisan
I've been looking into arduino, especially since I'm contemplating a brake and turn signal controller also. I enjoy C, haven't done it in a while. Don't much object to paying the money per se, just to paying it for a pot and a couple of wires.
Old 16-01-13, 06:37 PM   #8
bellisan
The resistance on the elements is 3ohm so max dissipation wil be about 50W, so should not cook. Besides I like to take projects like these as opportunities for learning, e.g. about power MOSFETS, software controlled feedback loops, sensor interfaces, etc.
Old 18-01-13, 03:43 PM   #9
embee
embee's Avatar
Plenty of stand alone off the shelf 12V pwm controllers available for pennies, like this for example . They are often described as motor speed controllers. At that sort of money I wouldn't bother messing about making anything, just put it in a box.
Where/how did you mount your heated grips controller? Fifteen15 SV Talk, Tuning & Tweaking 10 26-03-12 08:51 AM
Heated Grip Controller munkygunn182 Stuff Wanted 4 19-10-11 05:33 PM
Heated Vest For Sale (New) cb1000rsteve For Sale - Other Bikes and General biking items 2 01-07-11 07:40 PM
Brand New Heated Vest For Sale cb1000rsteve For Sale - Other Bikes and General biking items 13 01-12-10 10:45 PM
New oxford heated grips controller Alpinestarhero SV Talk, Tuning & Tweaking 21 30-09-08 03:00 PM
