Old 06-02-13, 05:30 PM   #1
Tsioumas
Default Curvy idles at 5.000 rpm
Hello there,
I have a curvy 2001 model (55.000 kilometres) which idles/revs itself at 5000 rpm seconds after starting up.
Probably a vacuum leak, but don't know from where. I only figured out it is in the front carb, when I close the upper part (without filter on) with my hand, idle comes down to normal. This means too much air to the mixture (running lean), right?
Carbs cleaned, fuel changed. Checked float level, checked choke cable (o-ring changed), checked spark plug. There are no vacuum lines in the front carb, right? I cannot take out intake boot to check because screws are shield, but can a vacuum leak there cause so much rise to idle?
Suggestions please
Old 06-02-13, 05:34 PM   #2
Noddy
Default Re: Curvy idles at 5.000 rpm
Start simple, have you considered adjusting the idle screw? (Located on the L/H side of the bike in the triangle cutout of the frame).
Old 06-02-13, 05:43 PM   #3
Tsioumas
Off course, it is set to 1400 rpm. When I close the front carb intake with my hand idle is fine, when I take off my hand rpms rising again. I have taking out carbs and disable them numerus times, no luck.
Old 06-02-13, 06:49 PM   #4
Grant66
Grant66's Avatar
What do you use to check the carb balance? Front right and in the most inaccessible place Suzuki could find.
Formerly known as Gajjii
Previous Bikes: Red Sk1 Curvy, Red MT-07.
Current Bike: Black MT-09.
Grant66 is offline   Reply With Quote
Old 06-02-13, 07:02 PM   #5
Lawman
Are diaphrams ok?
Old 06-02-13, 07:16 PM   #6
Tsioumas
I didn't checked carb balance, don't have a gauge available. You reckon that carbs out of balance can cause that? I did messed up with carb synch screw
Old 06-02-13, 07:39 PM   #7
rb8989
Air leak... orhow are you for fuel? If your carbs are nearly empty the bike runs lean for a bit before dying. Happened after work today.. bike would not idle and was surging.. Switched to reserve and all was well.
Old 06-02-13, 08:01 PM   #8
Tsioumas
5 liter fresh fuel after I cleaned carbs
Old 06-02-13, 09:04 PM   #9
Grant66
Grant66's Avatar
No. Was just pointing out that the front carb has a vaccum. There should be blanking cap on it.
Old 06-02-13, 09:08 PM   #10
Tsioumas
Oupps, I know that, but no line
Speedo from a curvy S fit into a curvy Naked housing? Taipan SV Talk, Tuning & Tweaking 6 18-02-10 04:59 PM
Naked Curvy Bottom yoke and Curvy speedo drive 21QUEST Stuff Wanted 6 29-01-09 09:36 AM
My SV idles too high. Taylor1975 SV Talk, Tuning & Tweaking 8 24-03-08 12:36 PM
thought i best post some here, curvy lowers on my curvy BIKER-DENE Photos 3 06-05-06 07:26 AM
Engine idles at 1000, why? jim6800 SV Talk, Tuning & Tweaking 7 23-12-04 02:47 AM
