Old 21-02-13, 10:39 AM   #1
redeye321
Default Long commute - service intervals?
Over the years I have slowly moved further away from my job in London and deeper into Kent. Now living in Faversham and looking at a 100 mile commute to work everyday. The bike is a K4 with 66000 miles on the clock. I would say about 95 percent of my journey will be motorway. I'm wondering if I will have to change my servicing schedules because of all the motorway work?
Sent from my GT-I9300 using Tapatalk 2
Old 21-02-13, 10:45 AM   #2
ChrisCurvyS
ChrisCurvyS's Avatar
Default Re: Killer commute
Dunno but I'd go two teeth up on your front sprocket. I've got a long motorway commute and it's helped massively - much less buzzy and about ten more miles before the fuel light comes on.
Only doing 6000rpm at 90, about 5000 at 70.
ChrisCurvyS is offline   Reply With Quote
Old 21-02-13, 10:51 AM   #3
redeye321
Too late I have just changed my chain and sprockets. Will remember that for next time.
Old 21-02-13, 10:59 AM   #4
NTECUK
NTECUK's Avatar
Stick with your recommended one.
Old 21-02-13, 12:25 PM   #5
If it's solely doing 100 mile motorway trips you could stretch the oil changes out a bit if you wanted without too much issue. It's very light duty for one depending how fast you go.
But for the sake of saving £1/1000 miles it's probably worth just sticking to standard services.
Old 21-02-13, 12:38 PM   #6
Ceri JC
+1
I found that you can safely stretch the service intervals a bit if you're doing lots of long distance motorway riding. Riding in London itself (lots of stop starting, hard acceleration and braking, poor road surface working the suspension) is quite taxing on a bike. Banging along at a constant 80mph on the motorway isn't.
The main reason I chose to do this was not one of cost saving, but rather time saving: money aside, it's a real pain to service the bike very regularly (as is necessary when doing high mileage) even more of a nuisance if you can't do all the servicing yourself and need to take time to drop it at a dealers, make alternative travel arrangements whilst it's out of action, etc. Yes, it's a gamble, but one that paid off for me and I never experienced a breakdown as a consequence.
Old 23-02-13, 05:52 PM   #7
suzukigt380paul
Default Re: Long commute - service intervals?
run it on good quality fully synthetic bike oil,and change the oil every 8k.just like every honda i own
Old 24-02-13, 08:27 AM   #8
Fallout
Fallout's Avatar
Sounds like you think motorway work is more taxing on the bike. It isnt, so long as your not screaming along in the high rpms. Its probably better per mile for all components.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 24-02-13, 10:03 AM   #9
redeye321
Must admit I did think that it was working a lot harder on the motorway. I was thinking my bike was reaching the end of its life due to the mileage that I have put on it but hopefully I should get a bit more use out of it.
Old 24-02-13, 10:19 AM   #10
Winder
Winder's Avatar
Engine is not even close to the end of it's life. It's the other bits you need to keep and eye on for corrosion etc, british weather and crappy road salt are your main enemy not the mileage.
You say you have just got new chain and sprockets, if you don't have one already i would recommend a scottoiler or similar lubrication system to really extend the life of your chain drive.
Service intervals MCN_LiamM SV Talk, Tuning & Tweaking 11 08-05-09 12:44 PM
Service Intervals H SV Talk, Tuning & Tweaking 6 03-01-07 07:45 PM
service intervals tiggersv SV Talk, Tuning & Tweaking 1 26-03-06 01:38 PM
Service Intervals monkfish SV Talk, Tuning & Tweaking 3 09-11-05 05:55 PM
service intervals silent SV Talk, Tuning & Tweaking 3 07-06-05 08:43 PM
