Old 21-02-13, 05:20 PM   #1
Fraser1200
Default Indicator warning light problem after LED indicators fitted. Pointy.
http://www.youtube.com/watch?v=Y0mLvJp-lHc
not a great video but hopefully get the idea.
All indicators are Leds and this has just started are they were all replaced.
the indicator light never fully goes off then back on it justs fades.
i have a relay in and the flash rate is fine
any ideas?
Old 21-02-13, 07:30 PM   #2
Tomor
Tomor's Avatar
Default Re: Stuttering Indy
mine does that, albeit when it 'goes off' its not as bright as yours. I think it is something to do with the relay. Alternative is just to not use your indys and wave your arms
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 21-02-13, 07:39 PM   #3
It's because with all LED's there isn't enough load. Add a normal bulb and hide it or fit a resistor. I just left mine. Doesn't bother me too much. You just notice it at night
Old 21-02-13, 08:42 PM   #4
Fraser1200
i was just wondering if it is goin to be a problem but if you (darren) havent had any that makes me feel better. my mate did say that the indicator itself was actually stuttering aswell when sitting at lights but that might have something to do with the idle being a bit low.
if i pop a resistor into one of the indys wont it just sit about and get really hot?
Old 22-02-13, 12:53 PM   #5
MJC-DEV
MJC-DEV's Avatar
Default Re: Indicator warning light problem after LED indicators fitted. Pointy.
No, because its only a few mA of leakage current that is way too small for a bulb but enough for a slight glimmer through an LED.
2006 SK6, wavy discs, 8.5N K-Tech springs, Debrix Emulators, Nitron Shock, Silkolene RSF Pro 10W, Eastern Beaver H4 Dual Headlight Relay Kit, Avon Storm Ultra 2 tyres, Ebay billet brake/clutch levers
MJC-DEV is offline   Reply With Quote
Old 29-11-13, 05:22 PM   #6
d3l
Mines doing the same.......was yours ok at MOT??
Old 29-11-13, 06:11 PM   #7
Yeah fine. I don't think they are too concerned about the dash lights
Old 01-12-13, 11:00 PM   #8
stuR
Have heard a few people on here with that problem as above. Id just leave it..not gona do any harm.
Old 03-12-13, 06:13 PM   #9
Toooldtodie
Toooldtodie's Avatar
This problem has been raised before, but the resistors supplied do not seem to emulate the resistance of an incandescent bulb. PM me and I'll send you a pair of resistors that should solve all your woes! Just one required per circuit and job done. Or if you want to, you can get a pair of W22 6R8 vitreous enamel resistors. Wire them in as though they are short-circuiting the circuit and problem of flash rate, etc. should vanish.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
LED indicators fitted - dash light on constantly. FG1 Bikes - Talk & Issues 3 04-08-10 08:34 AM
LED Flush mount indicators fitted - problem. Rcollarbone SV Talk, Tuning & Tweaking 19 15-05-10 06:07 PM
SV650s K2 Indicator Warning Light not working kd80 Bikes - Talk & Issues 0 05-04-10 08:51 PM
pointy rear light with built in indicators sv650nutter149 Stuff Wanted 0 05-04-08 07:53 PM
Indicator/Fuel warning light distraction? oldjack SV Talk, Tuning & Tweaking 22 25-09-06 03:55 PM
