Old 22-02-13, 02:30 PM   #1
matt_rehm_hext
Default Cleaning front caliper corrosion?
Hi
Look at this:
I've cleaned everything with brake cleaner, and scrubbed the seal grooves with autosol but can't shift the rest of the white stuff out.
Any tips?
Old 22-02-13, 03:15 PM   #2
Default Re: Cleaning front caliper corrosion..
Is that in the seal groove?
If it is get a dremmel and a brass brush attachment and slowly go round the groove. They'll come up a treat
Old 22-02-13, 04:04 PM   #3
matt_rehm_hext
Yeah, dust seal groove.
I have a silverline tool like a dremel and I think there's a brass brush attachment, I assume it won't damage the caliper metal?
Old 22-02-13, 04:07 PM   #4
Nope if you do it at low RPM
Old 22-02-13, 04:14 PM   #5
matt_rehm_hext
And I guess use Autosol at the same time?
Old 22-02-13, 04:36 PM   #6
Nope I used nothing, just washed them with Gunk (or Jizer) to get rid of all the crap thrown off
Old 22-02-13, 08:15 PM   #7
muzikill
muzikill's Avatar
Try and get them cleaner than i did and ill be impressed. Well done for doing this.
Brake Caliper cleaning Question appollo1 SV Talk, Tuning & Tweaking 6 03-06-12 01:33 AM
Changing pads and caliper cleaning - few q's dyzio SV Talk, Tuning & Tweaking 8 19-08-08 07:39 PM
Caliper cleaning RingDing SV Talk, Tuning & Tweaking 4 10-03-08 02:00 PM
Corrosion On Front suspension bingopaul SV Talk, Tuning & Tweaking 5 01-02-06 05:09 PM
Front fork Corrosion Banus SV Talk, Tuning & Tweaking 4 18-03-05 08:23 PM
