Old 19-03-13, 11:09 AM   #1
granty92
Default Front wheel bearing noise?
This may be a dumb question but there is a very faint whining coming from my front wheel when riding(not under braking) I'm guessing this is the bearings, are there 2 sets of bearings per wheel like a push bike?
Old 19-03-13, 01:24 PM   #2
Default Re: Bearings
One in each side, but they are sealed units not cup and cone and loose stuff.
Old 19-03-13, 01:44 PM   #3
Blueperson
Get the front wheel off the ground and feel for side-to-side play.
Old 20-03-13, 08:52 PM   #4
Stonesie
Default Re: Front wheel bearings?
When my front wheel bearings went there was a whine like you describe but no side to side play, when the wheel was turned though it felt 'gritty'.
They're pretty simple to change and not too expensive for good quality parts, I like SKF, probably from working around the rail industry and them using that brand.
The bearing size for a K3 like in your avatar is 17x40x12... you need 2 sealed ones.
Old 21-03-13, 01:40 PM   #5
kiggles
Default Re: Front wheel bearing noise?
had same problem on mine at first. Then i got pulsing in brakes always though it was worped discs because that what MOT man.
But £22 (i think) for OME bearings and sorted all the issues out. Right side probably worse as that is the side more exposed when bike is left on its side for a while outside.
Old 21-03-13, 01:42 PM   #6
granty92
nice one guys, will look around now
Old 21-03-13, 10:16 PM   #7
otaylor38
I don't know if its just mine, but my speedo rotor made a loud whine even though the speedo was still working. Maybe check that if other things seem to be okay? Defo wheel bearing first call though
Old 22-03-13, 10:07 AM   #8
chezza
chezza's Avatar
Hi Guys, Funnily enough I have a similar noise on my bike and was going to post the question today !
What sort of mileage would you expect a bearing to fail ?
Also, where can I find the speedo rotor ?
Gav
chezza is offline   Reply With Quote
Old 22-03-13, 10:17 AM   #9
chezza
chezza's Avatar
just to add - mines a 2010 Pointy - not sure they have a front wheel driven speedo rotor, but happy to be corrected.
Also, the noise I am getting is a droan around 60-70mph that I can hear over the engine, and also a low grinding noise between 15-25mph
Gav
Old 22-03-13, 10:23 AM   #10
granty92
gav i get exactly the same at the same speed and revs, will be getting bearings and rotor done soon
wheel bearing covers barwel1992 SV Talk, Tuning & Tweaking 6 05-11-09 10:05 PM
Front wheel - scraping noise monkeydispenser SV Talk, Tuning & Tweaking 6 14-07-08 09:47 PM
Front wheel bearing shot? DanAbnormal Bikes - Talk & Issues 4 18-05-08 10:01 PM
Front Wheel Bearing Seals lawson17 SV Talk, Tuning & Tweaking 1 08-10-07 01:23 PM
Humming sound from front of bike, wheel bearing? trailer_parks SV Talk, Tuning & Tweaking 7 09-12-04 01:30 PM
