Old 22-03-13, 06:53 PM   #1
Stuuk1
Default Question For The Org Plumbers..
Hi all!
Shall be installing the pipe in the wall for my new electric shower tomorrow (cold feed only).
My question is, will condensation be an issue when buried in a wall behind tiles?
I think I heard somewhere once that I may need wrapping in something but surely pipe insulation is too large / overkill?
Thanks!
Old 22-03-13, 07:27 PM   #2
Bluepete
Bluepete's Avatar
Default Re: Question For The Org Plumbers..
Oh.
Not me then.
I'll get me coat!
Pete
Old 22-03-13, 07:33 PM   #3
Bluefish
I don't believe it would be an issue, never seen one lagged/wrapped, if there was room then yes lag it but if not, maybe use plastic pipe?
Old 22-03-13, 08:00 PM   #4
Stuuk1
Originally Posted by Bluepete View Post
Oh.
Not me then.
I'll get me coat!
Pete
Sorry Pete! If you have some useful input then please do input it!
I am going to use plastic, am I being stupid and thinking plastic wont gather any condensation...?!
The shower says it doesn't recommend using push fit connectors but I chucked one on just to see and it fits fine!
Old 22-03-13, 08:24 PM   #5
Condensation won't be a problem, plastic fittings will be, use speedfit pipe but compression fittings (with inserts).
If you have a problem with the shower, if you haven't fitted it exactly to their recommendations, they will use this to get out of any warranty claims.
Old 22-03-13, 08:24 PM   #6
Bluefish
Condensation will be minimal with plastic, don't forget to get a qualified electrician to wire it up and write out the necessary documentation ;0)
Old 22-03-13, 08:26 PM   #7
Bluefish
Yeah don't forget the inserts, bet you never have eh Phil?
Old 22-03-13, 08:30 PM   #8
NTECUK
NTECUK's Avatar
I used plastic on my sisters and swoped to chrome plated using a compression fitting .
Plastic has better thermo insulation than copper and as its buried under tiles then not much water vapor is likely to reach it.
Old 22-03-13, 08:30 PM   #9
Nope, I haven't but I've seen many DIY jobs that haven't used them, I literally touched a radiator pipe once and it shot out of the compression side of the valve, a little knowledge is dangerous.
Old 22-03-13, 08:33 PM   #10
NTECUK
NTECUK's Avatar
Now that's s "You've been framed "moment lol
.Org Plumbers? Dave20046 Idle Banter 213 09-04-12 08:51 PM
Question for Org Plumbers aliwakeskate Idle Banter 7 20-02-12 10:52 PM
Any plumbers out there Mrs DJ Fridge Idle Banter 5 20-02-12 10:20 PM
question for org plumbers and heating engineers timwilky Idle Banter 12 28-10-10 09:24 PM
Plumbers - combi boiler question steveg Idle Banter 28 04-11-08 09:11 AM
