Old 24-04-13, 01:36 PM   #1
craig dow
Default Abba stand - where from?
looking at getting an abba stand , can you get the forks of using one , not sure if it lifts the bike high enough or not , any idea the best place to get one from ? or if you have one for sale please let me know , thanks
Old 24-04-13, 03:21 PM   #2
dkid
Default abba stand
Abba stands are great bits of kit and are worth having if you do regular work on the bike. If your planning a one off or infrequent job (fork removal) there are other ways.
Ratchet straps under the top yoke and over a roof beam/rafter worked for me once. Car jack under the engine will also work if you're careful. I ended up buying a headstock stand as I already had a rear paddock stand. This also allows removal of the forks.
Like I said, abba stands are great. Just make sure you can justify the cost to you personally.
Old 24-04-13, 03:25 PM   #3
Tomor
Tomor's Avatar
Default abba stand
I used mine to get my forks off on the sv. Coupled with two bits of wood under my crash bungs lifted it high enough.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 24-04-13, 05:18 PM   #4
JamesMio
Default Re: abba stand
As above, ABBA stand + car jack under the header pipes was all I needed to be able to drop the forks out of the Blade.
Never even looked like it was going to shift, they're brilliant bits of kit.
"That **** on the push-bike."
Creatomatic
Old 24-04-13, 05:45 PM   #5
fizzwheel
fizzwheel's Avatar
Moved to bike talk
Old 24-04-13, 06:12 PM   #6
Mark_h
Mark_h's Avatar
Now if Ralph were around he'd make you one for a fiver out of a curlywurly and a dead slug.
One advantage of the abba is that the pivot point is quite a way forward so any sort of heath robinson front end lift you cobble together has less effective weight to lift. However for under £40 you can get a front headstock lift which works well with an abba. <Link>
Minister for Sustainability
Old 25-04-13, 06:42 AM   #7
Spanner Man
Good morning all.
Not being a fan of jacking bikes on the engine or exhaust, & for those with a garage, who indulge in regulat twiddling. A good tip is to sink a couple of folding hooks into the floor. The type HGV's use on trailers.
Park the bike on the Abba, with the rear wheel between the hooks, & use a ratchet strap through the wheel to lift the front. A jack under the engine/exhaust can then be used as a steady.
Cheers.
Spanner Man
Old 25-04-13, 07:20 AM   #8
craig dow
thanks for all the info , I jack my bike up on a beam in my shed with ratchet straps , but it is a hassle , so im going to get an abba stand , just trying to find a good deal on one , all about £100 on ebay , just wanted to know if any one new of any where else where I could get one cheaper , thanks again
Old 25-04-13, 11:32 AM   #9
Supervox
No more Mr Nice Guy
Supervox's Avatar
Check the company's website - a Superbike stand + fitting kit (if req'd) + P & P = £106.90.
Why buy from Ebay when you can get brand new for near enough the same price?
Never argue with an idiot - he'll drag you down to his level and then beat you with experience
Supervox is offline   Reply With Quote
Old 30-05-13, 01:40 PM   #10
IRMO
Does anybody know which abba fitting kit fits the sv650 and which other bikes it fits? Also will the sv1000 kit fit the 650?
NWS centre / swingarm stand. Like abba stand quik_d For Sale - SV's and SV related items 4 15-04-13 09:24 PM
abba stand hindle8907 Stuff Wanted 1 21-03-11 01:05 PM
Paddock stand/abba stand or? Ruthja2801 Bikes - Talk & Issues 18 26-02-09 12:20 PM
Abba Stand... Drew For Sale - SV's and SV related items 17 10-01-09 07:32 PM
center stand / abba stand? New Leaf Bikes - Talk & Issues 3 29-01-08 01:58 PM
