Old 26-04-13, 08:24 AM   #1
granty92
Default Coolant removal - how?
Hi guys and gals
So yesterday for some unknown my radiator cap was loose and the bike wee'd all the coolant so I chucked some water in as I was 50 miles from home and it got me back safely, today I will be getting new coolant, is there a particular one? Also how do I empty the water out of the rad?? Thanks in advance
Old 26-04-13, 08:40 AM   #2
dirtyred619
Default Re: Coolant removal
This might help.
http://www.youtube.com/watch?v=vNHqmGKqMdk
Old 26-04-13, 08:42 AM   #3
Dicky Ticker
Drain the whole lot out, buy premixed coolant and refill, check for air locks by squeezing the hoses.
By using premix you know you have the correct mixture.
Alternatively if you have a coolant hydrometer to check the specific gravity of your mix use raw coolant
Old 26-04-13, 08:45 AM   #4
jambo
jambo's Avatar
1. Undo rad cap
2. Undo water pump drain bolt on the right hand side of the engine.
3. Watch water come out at a surprising rate and angle & spill all over the floor.
4. collect what's left
5. re-seal water pump drain bolt.
6. Lift tank &undo expansion tank filler cap
7. undo small line from just below rad cap to expansion bottle and lower it so water drains into the bucket from there too.
8. reconnect everything, re-fill with chosen coolant (anything for a modern car / aluminium engine will be just fine) first the radiator then the expansion tank.
9. start the engine to work out any air locks then check levels again.
10. beer time!
Jambo
Old 26-04-13, 08:55 AM   #5
granty92
Nice one will be getting done in a moment
Old 26-04-13, 08:55 AM   #6
NTECUK
NTECUK's Avatar
Default Re: Coolant removal - how?
Don't tip the old stuff down the drain,take it for proper disposal.
Old 26-04-13, 01:02 PM   #7
m`baubz
edited slightly for less mess
Originally Posted by jambo View Post
1. Undo water pump drain bolt on the right hand side of the engine.
2. holding a bucket against the drain undo rad cap
3. Watch water come out at a surprising rate and angle into the bucket
4. look around for suspicious types
10. beer time!
Jambo
Old 26-04-13, 03:53 PM   #8
veenee
this guide can help as well:
http://bolty.net/2009/08/19/how-to-c...in-your-sv650/
Old 11-05-13, 04:07 PM   #9
lordra
Link doesn't work anymore.
Old 11-05-13, 05:18 PM   #10
veenee
Yep... Looks like the whole site is down... Shame...
Edit: It looks like it is back up!
Coolant Gary C SV Talk, Tuning & Tweaking 3 14-08-09 11:29 AM
Oil in coolant ?! fatneck Bikes - Talk & Issues 16 26-02-08 09:14 PM
Coolant - what to use Flamin_Squirrel Bikes - Talk & Issues 8 22-10-07 03:38 PM
Chain buffer removal requires swing arm removal :-( 2mths SV Talk, Tuning & Tweaking 1 09-07-07 09:19 AM
Sorry -coolant again tomjones2 SV Talk, Tuning & Tweaking 6 17-06-06 09:47 AM
