Old 03-05-13, 09:56 AM   #1
Ross
Wink Loose mirrors?
Hi all just a quick one, I'm having a problem when I fold my mirrors in at night to put ya bike away, the next morning I take my bike out fold the mirrors back and what would you know there looser than a wizards sleeve so out comes trusty alum key to tighten them back in place. Is there anything I can do to prevent them coming loose? Thanks guys
Old 03-05-13, 10:55 AM   #2
kiggles
Default Re: Mirror problems
I have same problem. the trick is not to move them, put your helmet on them, or bump into them.
I also got the top part of mirror where ball joint is all floopy, had to cut into plastic to tight bolt and its still slightly floopy =[
Could always buy a new one, they are bit stiffer
Old 03-05-13, 02:56 PM   #3
missyburd
Default Re: Loose mirrors?
Duct tape?
Old 03-05-13, 06:18 PM   #4
Eulaca
probably not the best answer, but I found I could loosen or tighten the screw by the way I held the mirror when I moved it back & forth.
i.e I would hold the mirror stalk and apply some upwards pressure as I moved it and it would cause the mirror to grip the bolt slightly and tighten it in place as I moved it into position.
Is my clutch loose? N8te rider Bikes - Talk & Issues 2 22-07-10 07:24 PM
Loose exhaust - how to fix? kd80 Bikes - Talk & Issues 18 19-07-10 07:52 PM
Loose nut? Or should it be like this? jking Bikes - Talk & Issues 12 12-07-09 06:31 AM
loose Throttle jans1971 Bikes - Talk & Issues 6 04-09-07 07:48 PM
Loose Nut Ratty SV Talk, Tuning & Tweaking 0 05-02-06 04:59 PM
