i have a loose throttle , i went over a bump the other day which made me move the Throttle just a bit and made me leerch forward which could be dangerouse . are all new sv like this . can i do some thing to stop this happening again
Loose throttle? Is ther lots of free play in the twistgrip? does it move side-to-side? theres always a little bit of free play.
Take it easy over bumps in the meantime! Matt |
The torque of the bike at low revs is pretty strong too- what gear were you in? First can be a little lively- try a little clutch control with it.
As Matt said above though- there should be a couple of mm of free play in the throttle before it engages. |
The Sick Man
The slack in the trottle is part there to help against sudden jerks of the trottle and also so that the streach in the cables when the steering is a full lock does not make the revs rise.
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
Because you are hunched forward on the SV, especially the S model, people tend to put weight down on to the bars. The trick is to use a light touch on the bars and use you stomach muscles to hold the weight of your upper body.
Not so easy for any length of time. I tend to put weight down on the straights and save my muscles for the twisties and town sections. It does make a big difference to control. Tim. |
as explained above, the sv can be snatchy in 1st and 2nd around town.
We've all done it I'd bet. Just part of the learning the bike process. The trick is, as "I'm a" said, to use your wrist/hand to open/close the throttle, and not brace your entire body against it...... and keep an eye open for the bigger bumps
Loose end this weekend? | Biker Biker | Soho Massive | 6 | 23-03-09 03:22 PM |
Newbie on the loose | cornishrider | Idle Banter | 19 | 05-09-07 11:52 AM |
loose throttle cables??? | sfstu | SV Talk, Tuning & Tweaking | 4 | 01-06-07 06:45 PM |
Throttle Loose | Duck-man | SV Talk, Tuning & Tweaking | 8 | 22-09-06 01:26 PM |
Loose Nut | Ratty | SV Talk, Tuning & Tweaking | 0 | 05-02-06 04:59 PM |
